J32 intake manifold options
Old 10-13-2015, 08:08 PM
lovic87's Avatar
I've done plenty of searching and googling and can't fund the exact answers I'm looking for. I'd like to get a bit more pep out of the 3.2 but without going overboard on cost. Is the 3.5 intake manifold worth getting, or should I just find another 3.2 manifold and have it port matched? I plan to go with the p2r spacer and thermal gasket, as well as TB spacer. I'm not trying to drop the cash for the j37 intake manifold-unless I find one on CL.
J series Kingdom (10-20-2022)
Old 10-13-2015, 08:30 PM
06 ASM TL
DrOwNiNgPoOl84's Avatar
I bought 3.5 MDX manifold off eBay to get me little something more for time, plus if ever make switch to 3.7, gives me top plate. Mag vs Alum, so little less soak. Slightly more airflow. Not real noticeable, other than heatsoak honestly
Old 10-13-2015, 09:15 PM
thisaznboi88's Avatar
Throw it in the trash and get a 3.7 I'm ad Tb would give u nice gain for around 400-500 bucks. The 3.5 I'm isn't bad either but doesn't have as large of a volume
Old 10-14-2015, 02:29 AM
lovic87's Avatar
I'm trying not to spend 500+ on the intake mani/TB before even counting in spacers, thermal gaskets, etc. Just trying to get bit more power without spending a massive amount.
Old 10-14-2015, 07:07 AM
gotta pay to play. Modding the TL is not cheap. power to ratio gain is horrible
alexander212 (04-25-2023)
Old 10-14-2015, 02:41 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
if you don't want to spend money, don't get a tb spacer. it does absolutely nothing
The following 2 users liked this post by sockr1:
EvilVirus (10-14-2015), pohljm (10-15-2015)
Old 10-14-2015, 06:55 PM
lovic87's Avatar
Even with a bored TB and ported manifold? I'm all down to save the cash and put it towards other things, but if it's pointless then screw it. I know how much a difference all the small things make-I had a 2l VW (115hp/122tq) making just over 130whp/140wtq, on a college budget. Granted, that car broke A LOT and wasn't anywhere near as nice as the TL, but Id like to take advantage of all the little things I can.
Old 10-14-2015, 07:19 PM
sockr1's Avatar
Yea save your money. It doesn't help our cars at all even with a ton of mods. There's some threads on it
Old 10-14-2015, 07:29 PM
lovic87's Avatar
I read threads for it and against it which is why I asked. So I'll rule it out and probably just go with the thermal gasket. But I'm still looking for IM info, if the 3.5 is worth it or just stick with the 3.2.
Old 10-15-2015, 11:54 AM
6spd-GERCO's Avatar
J-pipe and HFPC's over intakes all day.
pohljm (10-15-2015)
Old 10-15-2015, 01:14 PM
lovic87's Avatar
So the exhaust is more of an issue than the intake? I was already looking into cat deletes, should I just concentrate on the whole exhaust system for more bang for my buck then? Cat deletes, J-pipe and back? Is the stock exhaust size a restriction or should I go bigger? I'm not dropping 1k on an exhaust, I'll be having my local shop do it. Except the cat deletes, they wont touch that on a street car, but I have a way around that.
Old 10-15-2015, 01:58 PM
Jeff
Oh Sickest TL's Avatar
J37 intake works well with a bored j37 TB along with cold air intake and xlr8 j-pipe with xlr8 exhaust. I wouldn't waste your time on the j35 manifold.
The following 2 users liked this post by Oh Sickest TL:
alexander212 (04-25-2023), EvilVirus (10-16-2015)
Old 10-15-2015, 02:55 PM
Jeff
but on a side note I have a j32 manifold if your interested in going the ported route.
Old 10-15-2015, 03:37 PM
anx1300c's Avatar
The biggest gains for me were from HFPCs, 3.7 manifold/ported runners/ZDX TB/4" CAI (I group the four together as one mod) and Flashpro. (Not in any particular order) All three showed significant independent gains in trap speed. I would say all three were roughly equal, and all three could be felt seat-of-the-pants >5k rpm.
OP, the 3.7 swap has shown as much as 15 whp on a 3.0 Accord. It's expensive, but it makes power at the expense of some slight drivability issues (which can be smoothed out with Flashpro). I still recommend doing exhaust mods before swapping manifolds.
Old 10-15-2015, 04:22 PM
Jeff
^i dont have any drivability issues?
Old 10-15-2015, 04:27 PM
anx1300c's Avatar
You're an exception. Most people get some degree of rev hang and/or bucking.
Old 10-15-2015, 04:42 PM
sockr1's Avatar
i think it only applies to manual transmission as well. i don't have the bigger IM but i think i remember reading that.
the new flashpro checkbox helps it to a degree, there's even some rev hang from my setup and bucking in 1st gear, but the new flashpro option they added to the software helps some
Old 10-15-2015, 04:43 PM
Jeff
yea none of that but I do have a p1078 code. says intake manifold runner high rpm malfunction. so that butterfly valve in the top plate isn't opening or something? I switched the solenoid back to the 3.2 unit and same code came back. U know of anything? I can't figure it out.... Car runs fine though but I feel like it could be better if I can fix this code
Old 10-15-2015, 06:33 PM
lovic87's Avatar
I have an '04 5AT so no rev hang, but '04/05 aren't tune friendly, correctly?
Old 10-15-2015, 07:33 PM
-------Tim-------
Slpr04UA6's Avatar
^not with flashpro, unless 6MT, and a newer '07-'08 MT ecu is replacing the old.
Sucks for us '04-'06 AT's!
Old 10-15-2015, 07:46 PM
6spd-GERCO's Avatar
Nope 04-06 AT gets no love from flashpro. I would go with HFPC's over the cat deletes. They cost more but reduce rasp when you modify the j pipe and rest of the exhaust. Unless you have those I don't see why you need the larger intake.
The following 2 users liked this post by 6spd-GERCO:
EvilVirus (10-16-2015), lovic87 (10-15-2015)
Old 10-15-2015, 08:52 PM
lovic87's Avatar
I'm going to try to keep my exhaust semi-quiet so I'm not too concerned about rasp, as long as the overall tone and volume sounds good. I'm going to start looking into J-pipes and go from there. Thanks guys!
Old 10-15-2015, 11:04 PM
AccordFlex's Avatar
You will also see a nice gain if you decide to go boost with the 3.7L IM, TB, and PnP runners. For my setup, I definitely think its helps the system breathe a lot better. When I was N/A I gained about 12hp before I added the Flash Pro.
I do have some light bucking, but it wasnt too noticeable until i added the turbo.
Old 10-16-2015, 01:59 AM
lovic87's Avatar
I'm sticking with NA, my car has 152k on it and I'm hoping it will last me another 2 years as a pretty reliable DD.
Old 10-16-2015, 04:36 PM
Jeff
This really bugs me. so what do we do? get a ecu from a 07 AT?
Old 10-16-2015, 06:35 PM
6spd-GERCO's Avatar
The problem is the 04-06 Autos are 3 solenoid trans vs the 07-08 Autos which are 4 solenoid. The 04-06 Auto trans cannot be run with an 07-08 ECU. Not much you can do.
Slpr04UA6 (10-17-2015)
Old 10-18-2015, 07:34 AM
tomlinsonj's Avatar
In this case, if you plan on swapping out mufflers and adding a jpipe, don't make the first move of cutting out and replacing your stock resonator with another brand. Just a suggestion, but I am very happy with the performance sound when paired with magnaflows and OEM resonator. I would hold off on MM delete as well, and only do that after you have determined you want more exhaust note. But jpipe and mufflers as a first round of exhaust mods shouldn't set you back too much while providing a noticeable difference in the tone of the car.
Old 10-20-2015, 07:22 PM
lovic87's Avatar
3 Weeks ago, I had the res and MM deleted. So I'm kinda screwed in that aspect, but we'll see how things go and if need be Im sure I can find stock parts if I decide I'd rather go that route once I have the J-pipe
Old 10-28-2015, 06:56 PM
neptl99's Avatar
Will j37 intake work on j35a3? If so what TB should I use?
Old 11-02-2015, 06:42 PM
Jeff
^ yes and j37 TL TB is what you want to use
Old 11-02-2015, 07:04 PM
anx1300c's Avatar
Use whatever J37 throttle body is cheapest. A few years ago, the ZDX TB was significantly cheaper than the others, so most of us went with that one. I don't know the pricing structure now, but manufacturers always seem to start gouging when they see an influx of orders on certain parts.
Oh Sickest TL (11-03-2015)
Old 05-29-2018, 08:51 PM
Junie Ruiz's Avatar
I have mines for a year best investment ever love the extra power j37 TB
Old 05-30-2018, 04:23 AM
Joecop67's Avatar
You have mines? Is that legal?
Old 04-13-2019, 10:31 PM
5th Gear
Agriff's Avatar
3.5 intake swap
I got on ebay and got all parts of my 3.5 intake for cheep.40 for lower intake 50 for spacer 35 upper intake on my 01 acura cl. Just cleaned the parts thouroly and bam big gains.
Old 03-16-2022, 02:24 AM
Mactechaddixt's Avatar
Hey I have an 01 acura cl and I grabbed a 3.5 intake manifold off a mdx
Can you tell me exactly what you did so I can do it?
Old 10-12-2022, 03:52 PM
mikejones23345's Avatar
I know this is an old post, but I figured I would still chime in. More is not always better. In the case of the intake manifold, more attention should be paid to how easy air can flow and not how much air it takes in. Because if you bring in more air but it is still going through inefficient airway, you are just going to get a bunch of backed up air.
silvervtec96
08-16-2017 03:33 PM
ncciv
02-08-2016 05:10 PM
oVerBoost
02-01-2016 01:14 PM
Oh Sickest TL
10-15-2015 03:23 PM
Quick Reply: J32 intake manifold options
