Notices
Ď06 Accord 6 speed sedan build thread.
Old 06-02-2019, 11:58 PM
Registered Member
I bought the Accord in February 2018, it was in great shape aesthetically with only 90k miles. I got it as a DD/family car and I have already put 31k miles on it. But, coming from an Ď04 Mazda 6s 5 speed, while the transmission and engine are yards above the Mazda the chassis and clutch are (were) decidedly weaker. So, I caught the mod bug. Started with upgraded front brakes (legend GS calipers with accord coupe brackets and rotors). 19mm RSB from an 03 TL-S was next. Then a new slave cylinder with the check valve delete. Gm synchromesh tranny fluid, RV6 precat deletes, intake resonator delete, and a slightly ported/fully polished intake manifold are the rest of my current mods.
Along the way Iíve also done: full timing belt kit with water pump, pulleys and tensioner, did a valve adjustment, replaced a bent rim and all 4 tires, spark plugs, oil pan gasket and one ignition coil. The previous owner didnít do much maintenance evidently.
Altho this thing started as a pretty basic commuter car thatís still fun to drive, I have really enjoyed modding the car and learning as I go. Right now the goal is to go full sleeper mode. I have zero mods to the carís look and I plan to keep it that way.
In the next few weeks, the plan is to Re drill the battery support and move the battery over a few inches, and then build a custom 4Ē intake with the filter next to the battery. Then, fully port and polish the throttle body and runners and finish porting my intake manifold. Also Iím planning on doing an EGR delete and probably an oil catch can.
Eventually I want to buy a junkyard j32a3 and replace all the bearings and rings, get the block and crank re-honed, get some RL heads (with the RL cams of course) and port them myself, and basically be able to drop a new engine in the car. Iíd do a j36 build but I donít want to pay the ~$1500 extra to go thru all the necessary steps to get hondata in the Accord. This is and has been a super duper budget build. Iím cutting costs wherever possible. I figure a fully refreshed j32A3 with all my current mods plus ported RL heads with the cams should get me all the power Iíll need. I need a new clutch and flywheel soon so I figure I may as well start the engine build soon so it is ready to go whenever I pull the current engine to do the clutch.
#1Gaza is offline
08smr6mt (06-13-2019)
Old 06-03-2019, 12:39 AM
WTF?
Midnight Mystery's Avatar
The 7G Accord is my favorite car!
Ask anyone....
Midnight Mystery is online now
Old 06-03-2019, 07:39 AM
Received 14,119 Likes on 10,496 Posts
lol at spending mucho deniro on engines and porting and polishing but doesnt want to take advantage of tuning.
tuning WILL tie all of the mods you are planning together...it will immensely improve drivability and the best thing yet, prevent knock.
without the tune, you'll be running SUPER lean.
justnspace is offline
Saving4aTL (06-03-2019)
Old 06-03-2019, 08:08 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,205 Likes on 811 Posts
Don't cheap out!
gatrhumpy is offline
Old 06-03-2019, 09:22 AM
Registered Member
Do I want to get a proper tune? Yes. If there was a plug and play option I'd be all over it. But in order to get hondata in the Accord, you need an 07-08 TL ecu, custom harness, buy hondata, repin and rewire a bunch of stuff, and then pay for the actual dyno tune. I can get a junkyard TL engine for $300, RL heads for $300, new bearings and rings for ~$250, block honing and crank honing for around 400. I'll have around 1300 bucks into this build. Hondata would be more money than the entire build.
#1Gaza is offline
Old 06-03-2019, 10:52 AM
Rotrex + Comptech TLer
Saving4aTL's Avatar
Subscribed from the tone and enthusiasm for economy!
Saving4aTL is offline
Old 06-04-2019, 08:30 PM
sure, but what if you LOSE power?
i plopped on the 3.7l heads from the '10 MDX and LOST power. got the dyno to prove it too. was too embarrassed to ever show it
you're going to be running super lean with the ecu not optimized for the newer parts, you're planning.
and I did the ECU conversion. I found an 07 type-s 6MT ECU for $100 at a junkyard. I rewired my OBDII port and added teh canbus wire harness.
if you want the power, you need to get tuned!
Saving4aTL (06-05-2019)
Old 06-05-2019, 06:35 AM
Registered Member
Eh, Iíve done a lot of research and guys are still making power on the stock ECU, by and large. I am not going to keep my j30 ECU, Iíll get an Ď06 TL ECU. The stock ECU runs rich, actually, my car is running rich right now actually since I havenít really done much in the way of airflow mods and have the precat deletes.
#1Gaza is offline
Old 06-05-2019, 06:55 AM
Registered Member
Also, not planning on tuning is one of the reasons Iím not going to get the 3.7 intake/throttle body combo. Iíll just port the stockers, put in the P2R thermal gaskets and call it a day. Probably leaving some power on the table going that route but I hear the drivability of that mod without tuning is pretty bad.
#1Gaza is offline
Old 06-05-2019, 09:10 AM
Registered Member
Post some pics of this thing, my friend has a pretty built 06 2dr 6mt and makes around 260whp-dont quote me on that but my type-s and his is a really good race
90foxnotch is offline
Old 06-05-2019, 03:14 PM
WTF?
Aggreed!
Old 06-05-2019, 05:31 PM
Saving4aTL's Avatar
Rotrex the Accord!!
Old 06-05-2019, 07:16 PM
Registered Member
Haha. Sorry, definitely keeping this thing N/A. This is a daily driver, Iím mostly doing this build for reliability and fun, not max power. Plus, if I was going to boost a 6 cylinder family car Iíd be buying a g35. Front drive means that all that power from a supercharger is mostly wasted.
#1Gaza is offline
Old 06-05-2019, 08:47 PM
Saving4aTL's Avatar
Please develop your hypothesis...
zeta (06-05-2019)
Old 06-06-2019, 12:58 AM
WTF?
No! Just needs sticky tires, good suspension and deal with the torque steer...
C'mon... Saying you have enough torque to cause torque steer in a Honda is badass!
Last edited by Midnight Mystery; 06-06-2019 at 12:59 AM. Reason: Suck it! Again... :bored:
Saving4aTL (06-06-2019)
Old 06-06-2019, 06:37 AM
Registered Member
I mean, I said mostly wasted, obviously all that power would be pretty badass. But traction and wheel hop are already big enough issues as it is and thatís a whole other set of mods that would need to be done to the suspension, bigger sticky tires, solid mounts, etc. in addition to the cost of the supercharger. for a budget daily driver boost is not for me.
#1Gaza is offline
Old 06-06-2019, 07:23 AM
WTF?
What color/trim is your Accord, BTW?
Old 06-06-2019, 07:48 AM
Registered Member
Itís an Ď06 sedan, ex-v6 6mt, non-Nav, and the color is carbon bronze pearl with tan leather interior. To be honest I donít love the color, and the interior leather is not the prettiest either, but itís in great condition and black leather would be pretty brutal in the SC heat. minus the stock 17Ē 5 spoke rims and dual exhaust and red v6 badge it looks like any old plain Jane Accord. When I bought it it was the only 6mt accord sedan on sale in the entire US with under 100k miles, that i could find online anyway.
#1Gaza is offline
Old 06-06-2019, 08:26 AM
WTF?
OMG! Carbon Bronze is my FAVORITE color!
Old 06-11-2019, 04:12 PM
Registered Member
Question for all you knowledgeable J series gurus: so I have been thinking that if I am really gonna do a refreshed J32 with RL heads in my Accord, I may as well swap the RL crank and rods and do a J35. A bit of research on car-part.com showed that I can get a full RL engine for less than $500.
The question: any issues with the J35A8 RL crank and rods in the TL block?
Also, if I got a 3.5 TL-S 6 speed ECU, that should run the 3.5 build without issues I would think, as long as I used the right injectors, wouldnít it? Thatís without hondata (which I could add later). Iíd have to prolly build a custom harness but thatís doable
#1Gaza is offline
Old 06-11-2019, 04:38 PM
teh CL's Avatar
Why not a J35A6 (05' Odyssey LX)?
It's a direct drop in and will get you exactly what you want and save you a ton a money.
teh CL is offline
Saving4aTL (06-11-2019)
Old 06-11-2019, 05:33 PM
Registered Member
Because I am going to rebuild whatever motor I buy regardless - new bearings and rings. RL engine comes with the most aggressive OEM cams, stiffer springs, and forged crank and rods. Odyssey engine has cast internals and not as aggressive cams. Not sure if Iíd use the RL pistons or TL pistons, guess it just depends on bore measurements and what kind of shape each are in.
#1Gaza is offline
Old 06-11-2019, 06:44 PM
teh CL's Avatar
The J35A8 is definitely the best all around motor parts wise.
Curious why your planning to rebuild whatever motor you end up with, regardless of mileage? I get it if you plan to go with a 3.6 stroker but if not, seems like overkill IMO.
I swapped an untouched (except timing belt/gaskets) 120k+ mile J35A6 motor into my 6spd TL almost 2 years ago & it's going strong to this day, without an oil burning issue.
Of course, to each their own... just seems like the money rebuilding an otherwise stock motor could be better spent elsewhere...ie: hondata
teh CL is offline
Old 06-11-2019, 07:34 PM
Registered Member
Valid question for sure, and it would be more logical to just buy a drop-in if that was all I was going for, no doubt. But Iím mostly doing it because Iíve never torn down and rebuilt the bottom end of an engine before, and at the moment I have access to a shop with an array of tools at work, and a lot of time on my hands at work as well. So itís just a fun project and a learning experience more or less. Also, I want a trouble free engine for a couple hundred k miles, because work is paying me to travel right now, approx every other week a 600 mile round trip is in the books. The weeks that Iím not traveling Iím bored AF.
#1Gaza is offline
Old 06-11-2019, 07:46 PM
teh CL's Avatar
Fair enough. I'm always curious when I see similar posts on the subject.
In for updates..
teh CL is offline
#1Gaza (06-11-2019)
Old 06-14-2019, 09:21 AM
Registered Member
Im pretty sure this car does not exist with the lack of pics
Old 06-14-2019, 12:51 PM
Registered Member
Here it is. Good shape, but no visual mods at all.
#1Gaza is offline
Old 06-14-2019, 01:06 PM
Registered Member
Looks good sir, Very deceiving! Looking forward to your progress
Old 06-14-2019, 09:08 PM
WTF?
Nice buy! SO beautiful! My very favorite 7G Accord trim/color too!
Old 06-17-2019, 09:38 PM
Registered Member
I did the throttle body coolant bypass last week
Definitely made a huge difference in throttle body temp. My throttle body now runs the same temp as my intake manifold instead of ~100 degrees hotter. Helps my factory airbox stay cooler as well. Now I just need the p2r gasket and an intake and I might be able to make some power when itís not winter.
#1Gaza is offline
08smr6mt (06-19-2019)
Old 06-17-2019, 09:42 PM
Registered Member
I did the Prank intake manifold and Tb thermal gasket. It is crazy how much they work. I can run my car hard for an hour and im able to touch and leave my hand on the intake itís barely warm. Before I would burn myself
Old 06-17-2019, 10:17 PM
Registered Member
Good to know. The rv6 precat deletes made the biggest difference in heat soak for me, I had virtually the same experience as yours with the thermal gaskets. Im hoping the gaskets will take combating the heat soak to another level for me.
Anyone ever messed with relocating the IAT to the intake, as opposed to the intake manifold? I was thinking that that might help my car not pull so much timing in the heat, but it also might make it run richer and with the PCDs it already runs rich
#1Gaza is offline
Old 06-17-2019, 10:40 PM
WTF?
That's why I love this platform so much!
It out performs 2/3 of the cars on the road stock, and is easy to mod!
I never heard of this mod but it sounds very interesting? And you know those J-series V6's are just incredible for revving a lot!
Saving4aTL (06-18-2019)
Old 06-17-2019, 11:16 PM
Registered Member
Theyíd be easier to mod if parts were easier to find and the ecu was more tune friendly, but the Honda j series has to be the easiest 6 cylinder to work on in recent history. My coworker asked me to work on his 2000 Nissan Maxima - both valve cover gaskets, spark plug tube seals, spark plugs, pcv valve, and vehicle speed sensor. I did it but My gosh what an unbelievably awful car to work on. I could have pulled both heads on my Honda in the time it took to clear all the tubes pipes sensors and unbolt the intake manifold on the Nissan just so I could get at the valve covers.
#1Gaza is offline
Old 06-18-2019, 02:39 AM
WTF?
That's why I'm scared to get anything but a Honda or Toyota...
Also, the J-series parts are so interchangeable, not that you'd need to, or atleast without tuning, but it makes it more straight foward to work on.
Weather it's a J30 Accord, or J37 TL, they are still really similar!
Drive a new V6 Honda, it'll still feel amost the same!
The following 2 users liked this post by Midnight Mystery:
08smr6mt (06-19-2019), Saving4aTL (06-18-2019)
Old 06-19-2019, 11:16 AM
Registered Member
We have a few 6 speeds. I started my8gen and was the tech mod. My 09 GFís car pretty much has all the same bolt-ons. Injen CAI and all the thermal gasket stuff. ATLP j pipe and cat deletes. Stock cat back to keep it a sleeper. I have a modded 08. Any of you guys have have the egr block off plates?
08smr6mt is offline
Old 06-19-2019, 02:34 PM
Registered Member
The EGR blockoff will throw a code if you donít have Hondata. but a user called nswdoc on v6p makes an egr bypass that blocks the exhaust gasses and has the egr pull clean air instead. It doesnít look too hard to machine - I think Iím going to make one myself - but heís still active on v6p if anyone wants to order one
#1Gaza is offline
Old 06-27-2019, 11:20 AM
Registered Member
Do you still have the Accord aluminum intake manifold? What helps with reducing heat soak is an updated magnesium intake manifold. I have a 07 AV6 and I'm about to swap in a 08 Acura RL mag intake manifold, it has an IAT port.
t-rd is offline
Old 06-27-2019, 11:31 AM
Registered Member
Yep still on the stock manifold. I am unsure about the manifold compatibility on an 08 RL manifold with my 6 speed; I believe autos and manuals have differences in the manifold design. My plan with the manifold is just to port the stock manifold and throttle body. The 09 TL-SH manifold plus throttle body (the best OEM combo) is like 800 bucks and has been known to cause bucking without hondata.
#1Gaza is offline
Old 06-27-2019, 11:38 AM
just get hondata already...you're DOING all of this; just to be held back
and have you heard of junkyards?
Quick Reply: Ď06 Accord 6 speed sedan build thread.
