Yet another Nexus 7 installation. '07-'08 no-navi TL specific.
Excellent writeup!
One of the cleanest jobs I've seen!
Nice. I have had a nexus 2013 tablet for many years and see a lot of threads about this. I also have a Navi 06 TL but like the idea of having the optoins of the tablet. I need to look further into this!
very good write up and it's great to get more write ups so people get confident to actually make the change. i'm glad my thread helped you out!
you have some good humor in your write up too haha.
i'm soo jealous you didn't put this write up before i did mine, if i could do mine over again i for sure would have hacked into my tablet and moved the power buttons and the usb location. that would make such a better power connection and very robust, not to mention easier to do a reinstall.
right now i'm having some audio issues still (whenever i play usb music with the DAC my tablet randomly freezes and reboots), and i may need to do a complete reinstall of timur's kernel, but your usb/power button relocation would have saved me soo much time and effort i might have to do. if i can't find a solution and need to reinstall, i need to take apart my entire head unit again and hook the tablet up to my computer. you did a very smart move, wish i had done that!
you're also right about poweramp having issues with usb music. i tested about 6 apps and found the best one for usb music is gone mad music player
what about adding reverse camera?
good job and enjoy!
good job and enjoy!
I had same issues with timurs - either stuck in powered OTG or freezing. That's why I decided to give it up. ElementalX still have activity in development, while timurs is "final".
the weird part about mine is that mine ONLY freezes when i have usb music playing through my usb hub and through my DAC. if i dont' have that exact combination, i have 0 issues with the kernel. tonight i'm trying some 2.0 hubs instead of 3.0 and hope that solves it. i think the DAC is not working well with 3.0 hubs. if that doesn't work then i will buy a DC-DC puck converter instead of cigarette adapter. if that doesn't work i tear apart my dash and reinstall the kernel (hope not!!)
I used buck converter for charging and powering DAC. DAC was making some really bad noises, so I would not recommend it. Just get some nice charger (I personally like anker products).
i am using anker right now. my DAC works perfectly for sound and sounds much better than without the DAC. it's just the random freezing and rebooting issue of the perfect storm of compoentns haha. still trying to figure it out
Can you post your tasker settings for gps location always on? I hate waiting for it to "sync" when I need to use maps
i for my music to auto play I'll post settings later it's pretty simple
fantastic job!!!!!
Create profile, for example of the state "is charging".
Then in task select "Get location", on source select GPS, check both "Continue task immediately" and "Keep tracking". Make sure you will do exit task that will stop tracking.
There's example I did on my phone:
And don't forget to post your play music task!
When you are creating profile go State - > Power - > power - > Any. It's "is charging" state I was talking about.
About GPS, that's help page if you download it to SD.
So I guess timeout means after how many seconds this option should expire. Actually didn't know about it.
But as long as task is running this option will not expire. So fix is something like ;
I will further test it out and edit first post.
Wouldn't know about it If not for your question. Guess I'm learning something every day.
Tablet is working fine right now. However recently two people managed to "break" OTG by turning key on/off repeatedly. Tablet was thinking it was charging, while it was giving power for USB devices. The only way to fix it was to shut it down (reboot didn't work). It might be kernel related as I'm using CyanogenMod and ElementalX kernel, but I decided to dig in my junk/parts drawer to make sure it will not happen again.
I created "delay timer" for powering the tablet. It will make sure that there will be slight delay (~5 seconds) before giving power to the tablet for the second time.
It might be achieved by simpler analog circuit, but I don't have enough knowledge to do that. Programming arduino was much simpler.
It's not nicest, cheapest, or most practical "device", but it's easy to make and it works.
There's parts list :
Arduino Nano - junk drawer, 3 boards for ~$12
Tolako 5v Relay Module for Arduino - ~$6, Amazon
uxcell 5V relay - junk drawer - 10 for ~$8 Amazon
Prototyping board - junk drawer
Polulu 9V Step-Up Voltage Regulator U3V12F9 - junk drawer, ~$4 for single board
Lithium Battery Charging Module Board Charger with Protection IC - junk drawer, 10 for ~$6 on ebay
Lithium battery from the phone, junk drawer. You can go for 18650 battery if you don't have anything
I don't have schematics right now, might provide it if somebody is interested. It should be relatively easy to wire up. I tried to explain it on the photos.
Right now I'm thinking that I didn't need separate relay for pin D12 (to signal arduino that there's power). Well it will not hurt anything
Couple photos :
There's code :
(use some auto formatting software before reading it)
Also try this link before opening the spoiler :
https://paste.ofcode.org/7DeiYXnKR9EN5UpURs9Gac
Now the plan is to put it between charger and tablet. I will also need to test how long battery will last, as this battery has more than 5 years.
Current drawn in "sleep mode" with blue LED attached is ~25mA.
Mostly because of use step-up and then step-down (in arduino) modules.
It should give around 3 days straight. Battery is charged with 1A, that takes around 2h from completely flat to full.
So if it won't work I will update this thread.
Couple photos :
Spoiler
Spoiler
JMiles_T (06-06-2017)
In the meantime, I use a switch to keep the tablet powered while I'm at the gas pump, and it's time to get moving again.
Spoiler
Hi.
Welcome in “Yet another Nexus Install” thread. I understand there are many other threads like this and they might be more descriptive and easier to follow, but I believe my approach is a little bit different. I hope this post will be useful for somebody.
So what are those differences ? Mostly because it’s 2007-2008 non-navi TL specific, I decided to keep radio and climate displays, and extend wires going to the tablet.
I will describe only those differences. Why? Because there are at least three good threads. Also I’m lazy. Just want to show off hah.
I just finished it (02/15/2017, 7:13pm) so I might do some changes in the near future – mostly to the tablet’s software. I will try to edit this thread. I will try to read my work, but as you might tell English is not my first language. Sorry for all weird sentences and words!
(Today when I'm writing it's 06/18/2017, couple bigger changes)
So first of all big thanks to couple guys who gave me ideas. It would never happen without you. Those are the “main” guys.
Projectwidow – idea for relocation. I might have executed it differently but plexiglass with tint is his. Thanks !
sockr1 – I had so many questions… His thread is great. Thanks !
ADay2Long – I used his thread for the list of material I might need. “His” wallpaper for the tablet was really nice. Again list of materials.
Some guy who posted service manual for my TL – helpful with disassembling interior and radio wiring.
Timur for the kernel
Authors of the apps I’m using
Factory Car Stereo Repair youtube channel – video for disassembling the radio
I’m going to divide this thread by order that I followed for my installation. Hopefully it will be clear enough.
Now nice photo to make you want to do it :
Part I : Nexus 7
Main parts list :
- Nexus 7, second generation, 16GB – look on ebay, for around ~$100. My was for $60 – broken USB port, but who needs it anyway?
- Wires – you might need OTG, and couple usb cables. I recycled whatever I had
- Bezel from ’04-’06 model. Ebay. I got mine for $40. Look for “#39050-SEP-A0”. That is its part number.
- FiiO E10K – most expensive thing on my list, $76. But totally worth it, even when my car has aux port
- USB HUB - I went with "AmazonBasics 4-Port USB 2.0 Ultra-Mini Hub"
(I did hardware mods first, as my Nexus arrived dead - broken USB port, meaning to way to charge it)
At this point you want to put one of the screen protectors on, or at least tape it. Keep screen nice, just temporary so don’t worry too much about dirt and bubbles.
I decided to open the tablet up and solder wires directly into the board. It has couple advantages, including stronger connection and less bezel-cutting. But tablet will look less nicely and you are risking breaking it. Look online how to disassemble it if you want to follow my lead.
Photos with description will be in the spoilers.
Spoiler
Time to cut out the ‘04-’06 bezel. Remove plastic glass and all the buttons/displays. Look for info in other threads. Procedure here for all 3rd gen is the same. One small hint tho – use something like dremel to cut out plastic from the inside, but take your time with a knife to cut through plastic on the outside (parts that will be visible). Photo above should give you an idea how tablet should fit in there.
Make sure the edges are nice and tablet is lying flat, like :
Spoiler
Software
]So there’s software configuration :
- Rom : Timur's Kernel
- For the background I’m using modified ADAy2Long background. Image and link to PSD under this list
- Tasker and “Secure Settings”
- Xposed – nice and powerfull. Root is only the first step in Android adventure hah
- AutoBright app
- AmazingText Free app
- Nova Lanucher – change grid size to 12x12 or something like that, the bigger the better. I will allow you to place widgets more precisely.
Additionally :
- GoneMAD Music Player - Poweramp had some weird issues with skipping/error reading files
- F-Droing - treat is as Play Store alternative (not illegal, just some extra apps that are removed from store)
- Adblock - downloaded from F-Droid app, it's against google rules I guess
- BusyBox - some apps might need it, useful in Terminal, probably will never use busybox features
- DriveSync - sync my music library that I keep on Google Drive
- Solid Explorer - my favorite file explorer, also connects with Google Drive
- Google Maps
- Sygic - only for offline/long trip navigation, when you are going to store/certain address Google Maps are more accurate
- Torque (and OBDII Bluetooth adapter) - just to read car data when I feel like something's wrong (never happened)
- "Today Calendar 2017"
- Youtube
- Titanium Backup - just in case
Xposed modules :
- GravityBox (MM) - configuration, using only couple options
- Youtube background playback - name says it all
- Youtube adblock - same
There's my background :
Spoiler
There's source file :
https://drive.google.com/file/d/0Byj...ew?usp=sharing
Tasker configuration :
(use separate profiles/tasks - this way you can reliably stop them if conditions change. Now in case of short power lose (due to starting engine for example) nothing should be messed up)
Spoiler
From my research hot glue shouldn’t melt in the summer sun, but practice tests shown that it will get much weaker (Chicago sun, ~90F out). You are risking your tablet to fall apart, so use epoxy. Really.
Don’t have a photo but I went quite crazy with it. Also try not sticking any metal things to the back of the tablet – it will mess up perception of wifi, Bluetooth, and gps.
I cut out metal bezel, so it had only the sides for the screws. I glued it to the bezel with the tablet. This way I’m hoping to keep nice GPS perception. I sanded and soldered the metal bezel on the edges – can’t weld and don’t have access to it. I holds surprisingly well, but some glue won’t hurt.
At this point I didn’t even touch my car. So worst case I lost ~$100 for tablet and bezel. It worked out nicely so I will keep going.
Part II : Disassemble the Car
Look for the service manual or other threads. Great resource was this video :
Make photos where what type of the screws goes, like that :
Yes. I’m working in the winter gloves. It was like 5F outside and I don’t have garage. Fun times. Not recommended though, plastic might be more brittle when it’s cold. But I didn’t broke a single clip.
Small note : At this point you might consider converting lights to LEDs. I replaced bulbs everywhere in that area. Much easier – you have it disassembled anyway. Start with climate controls – you should have a spare from the bezel you ordered.
Couple photos FYI :
Spoiler
It has 19mA at full brightness and around 15mA at my “normal” dash brightness. With max 24mA they should have nice and easy life.
Part III: Extending the wires
You will need to extend some wires. Wires for the buttons can be easily done at home. More is better than not enough. I also tapped into aux radio connection, and shorted two wires. My stock aux port still works, but radio thinks something is connected to it all the time. Also I didn’t try playing music from both sources (audio DAC from tablet and something from aux). Hopefully it can’t damage the radio.
Whole part in spoiler :
Spoiler
Part IV: Display relocation
So in theory there are couple ways to do it:
1. Leave the board in buttons bezel, behind the tablet, and extend wires for the display (around 48? Of them, some are dubled). Tried and it was harder, and tablet had problems with GPS with all that circuitry behind it. But it will be easier to glue displays and no need to modify vents or “complicated” install procedure
2. Move whole board. About same amount of the wires, but you need to solder couple of them in car. Need to modify vents, and if you decide to glue it like me… watch video on the very end
2a. Move whole board but make custom bracket for it (instead of gluing it to the plastic). I tried and failed. Didn’t have access to welder and metal, and used plastic was not strong enough to hold it.
3. Throw it out. Who cares ?
4. Relocate it to some other place. For example front bumper.
I went with #2.
Main parts list:
- Acrylic plexi glass – I used “Source One LLC 1/8 th Inch Thick 12 x 12 Inches Acrylic Plexiglass Sheet, Clear” from amazon for $14
- Automotive window tint – I used “Gila Heat Shield Plus 20% VLT Automotive Window Tint” for $15. You might want to go for darker one. When it’s sunny I can see display when it’s off.
Prepare tinted window first – it should dry for couple days. My had water marks under the tint but they went away after 3 days. Google how to tint windows if you never did. It was my first time and it worked nicely the very first time.
Spoiler
Spoiler
- Cut the damn glovebox - cabin filter easy to replace :
Spoiler
- External GPS :
GPS was fine for most part, Compass is wrong all the time (pointing in random direction). Never tested it before so I'm not sure if it because tablet is in vertical position, or my tablet's hardware is messed up. Because of that GPS was taking some time to lock, and it wasn't perfect all the time. When I went downtown Chicago it went all crazy, so I decided to fix it. I ordered USB module. It worked but was hard to automatize and it was randomly disconnecting. I didn't like idea of amplifiers, so I bought Bluetooth GPS module.
Which one? Well Dual Electronics XGPS150A. Amazon has them for ~$80 bucks. Expensive stuff. But :
- it turns itself on when connected to charger - but don't connect it to the usb hub, as it will try to communicate with tablet, and bluetooth module will stay off (other charger or cut data wires)
- it turns itself off when bluetooth disconnected for some time
- it's accurate, doesn't lose signal. Normally I don't have less than ~3m accuracy, and that's freaking amazing
- it's easy to automate and surprisingly works very reliable
Rest in the spoiler :
Spoiler
When you turn key on, tablet turns on immediately, now you start engine, and power is cutted out for about a second. With the right timing it will totally mess it up : it can reboot, don't detect USB devices, be stuck in OTG mode, signalize that it's charging while it's not etc.
To solve it I made delay module using arduino and relay.
Much simpler to use some timer IC, but at the time it was more complicated to I used arduino.
It's simpler than on the photos. Old ones :
Spoiler
If you feel ok, I suggest going with two relays and mosfet. Cheaper than this mosfet-relay module, same result.
Basic idea :
Spoiler
Spoiler
Final photos :
Spoiler
So… was it worth it? Totally. I actually really enjoyed the process (except the time when I needed to do it again). Love DIY projects, and while it was not the hardest one, it was most risky so far. Right now everything is working great. I put interior back together… and it looks weird. But awesome. I guess I got used to my car while I was driving without interior for about a month.
I learned a lot and got couple new toys (like dremel). Now I just need to convert rest of the interior to LEDs… and who knows? Maybe it’s time to take care of the timing belt (it's done now !)?
If you have any questions – I will try to answer them. But no promise, might get bored and forget about this forum.
Let me know what you think ! And good luck if you ever decide to modify your car !
Nexus install failed - HVAC and display shorted - urgent help needed
guys
started on relocating display for nexus install. Display would be moved where the cubby was. All modifications complete. HVAC controls extended as I am also moving the circuit board. need help, I cut all wires coming in below Center vent above dash to extend and in the process, shorted them as battery wasn’t disconnected. there was a spark and now everything is dead - blower starts by pressing Mode - something went wrong - any suggestions to check and fix. I am sure wires are extended correctly, but some fuse must have blown up???
Another Nexus install in progress
Hey guys
Looking for some input from fellow Acurazine who have inspired me to take on this difficult Install process for Nexus upgrade.
So a a detailed version will follow later, right now display relocation completed after a treasure hunt to find a blown up fuse while extending wires.
bezel modified to fit Nexus 7 and now working on software install. Has Anyone faces issues with rooting the tablet. I have installed trwp and device is detected on the computer using adp drivers but not been able to root the tablet. Once I go into stock recovery mode, computer now does not detect the device and adp connection is not formed. No yellow exclamation. Tried for 2 days to root, but not happening. Right now trying to force root by using SuperSU. Any other suggestions?
Huh my thread is a mess. First post missing, main post at #18. What happened?
Anyways, rooting the tablet should be simple.
What exactly are you doing? Are you installing Timur's or something different?
Nexus install - rooting
Post 18 - extended wires coming out of the car to relocate display into cubby section. While cutting them, didn’t take the battery out and shorted the wires with the same cutter .. yes - silly. Anyhow found blown fuse called BACK UP. All good to go there
post 20: I didn’t follow Timurs instructions on Rooting. There are new ways to trwp and root and my genius fri end used them .. we finally rooted and everything is up and running but we cannot connect to fastboot for adding a cmd for fast charge 0.. which is not needed if a relay is added.
now pending issues
- resolve start up issues: thinking of capacitor
- add a second power line while car is off and a switch something I saw JTmiles or Sockr had done
- figuring out how to fit up radio display - I didn’t cut the bezel. Radio had two ear tabs - I squeezed them through the bezel and simply glued the tabs. Bezel glass goes from outside with glue
1. Accident while extending the wires: So everything works good now?
2. What software/rom are you running on your nexus? I've been running old build of CyanogenMod, pretty sure version 13, but I would need to check.
Overall, I resolved all the issues and tablet was running 99% of the time since last December, but my current setup if quite different from what I wrote here.
I'm using relays and arduino to control everything. I also wired lithium battery charging module directly into tablet's battery to have a way to charge it when screen if off (that can be powered by relay by arduino).
It's over-complicated, but allows me to keep tablet powered when engine is cranking (your start up issue), and allows me to use charging+OTG outside the Timurs Kernel. That setup allows me to run any ROM except for Timurs.
i am not good at kernels and stuff, my friend help d me there. I am using Timur (I skipped a few steps) but eventually flashed with V4 through recovery
one Thing I cannot figure out is power up and power down videos - how do you make them work? I renamed the videos but they still won’t start
Null and proud of it
Cool! I have a question, when using a tablet in place of a nav device, does it need a service subscription like a cell phone? Does it need to be linked to the internet? Noob question for sure!
i am going to use Anker cigarette adaptor - not sure if Dc-Dc converter brings any additional value?
You don't need to use data to use navigation.
What I do is use Google Maps with "Offline maps" downloaded which expire every 30 days. Once a month you need to connect to internet (wifi at home) to update the map. Other than that the tablet is not connected to any internet (i only toggle wifi on when i need to update apps or maps at home)
Tablet should connect to the wire coming out of usb hub. Post a picture of the hub if you have issues. Also it won't hurt to test hub on the computer. If it does work on your pc or laptop then it also should work with the tablet.
Also I advice against using DC to DC and picking up quality phone charger. I used DC to DC that I had laying around and it produced some noise in the radio (as it also powers usb DAC).
Usb hub
My sleep mode from Timur Kernel works fine so not sure if it is a kernel issue. This is my biggest hurdle to get Audio from USB port
any suggestions?
PEM shows
usb host mode active
powering slaves no
external power yes
FI mode check box is grayed but allows to uncheck or check
- fast charging , firm sleep, disable secondary usb audio device
help needed
seems like OTH usb female port is not being recognized. Is there anyway to check or do?
i forgot to mention that usb cables are 3.0, OTG is 2.0, not sure if it matters
so I just ordered a new USB hub which is powered - Anker as per link from sockr. But I may have a different issue. My audio plays through nexus speakers. I even tried connecting DAC directly to the OTG usb but it still does the same. I am not sure which settings to change or verify.
any suggestions?
PEM shows
powering slaves no
external power yes
help needed
One tip - when I was troubleshooting, I connected computer mouse to my Nexus. It seems like mouse is easily detected, while other devices sometimes don't function. If it doesn't detect mouse, then there must be some other problem. Either cable you are using or software.
Additionally, press on "USB Devices" and check if DAC is on the list. Maybe the problem is with the music player that you are using.
Otg
so to be clear, I need to disassembly entire assembly and remove OTG cable including the micro USB port which is tucked inside the AC power buttons - urghhhh!!!
I have been clicking on usb devices to see if it detects my usb flash drive.
Before installing OTG I had ensured that FI mode is checked. As soon as I connected OTG, it grayed out. I will follow the sequence of micro usb to nexus, micro usb to power outlet and then OTG to mouse or flash drive.
i did forget to mention - thank you for your quick support ..
A
A
Otg
Cables don't matter, as long as they are decent quality. However, I tried using 3.0 hub and Nexus didn't recognize it. I ordered 2.0 Hub and it was working good for the past year.
I don't use Timur, but as far as I remember you want to disconnect all devices from Nexus, go to that app and select FI (fixed installation) mode, and then connect OTG cable and your devices to Nexus. In this mode tablet won't supply power to your devices, so you need to supply external power somehow. If tablet recognizes that it's in FI mode with OTG cable plugged in, that option should get grayed out. (you won't be able to uncheck it unless you disconnect the cable) Un-check that "disable secondary audio..." option.
still
- DAC is powered via OTG. I thought there won’t be any power coming from Tablet
- music still on speaker - DAC output blank
DAC connection
I think it boils down to DAC connectivity. Some forums talk about CM11 with elementaLX kernel and music starts playing over DAC for all apps. Not sure if Timur does that and I didn’t install something
I might have missed it but which DAC are you using?
I've done installs with both Fiio E10K and E07K on another car, hooked up to an Anker USB 2.0 Hub.
Both played music through the car speakers right away without having to touch anything in PEM, power event manager.
Dac
Peter, would you happen to still have the source image for your Nexus background without the icons? (Google Drive link doesn’t work). My OCD mind really likes how you reorganized/pushed everything up a little to make room for the soft keys below. I also noticed the tiny details where you took the time to fix the horizontal silver lines. Lastly, in your final setup, it looks like you changed the color of the stitching from blue to silver. I love it.
If you have that file, and are willing to share, please let me know. It would save me a lot of editing time. Thanks!
