XM Navtraffic Hardware in Canadian TL Type-S?
I want to get either the iSimple ISHD651 or the ISHD571 (with SBT21 Bluetooth Kit & possibly the PGHHD2C harness) so I can stream music from my iPhone via bluetooth and have the text display on the OEM radio screen, and my choice depends on if my car (I have an '08 Type-S) has the hardware in it for XM Navtraffic.
I've done a lot of searches here and elsewhere on the web, and I have yet to find a definitive answer whether or not the Canadian version of the TL-S has the hardware for XM Navtraffic or not.
I know that the service is not available in Canada, and I can't see anywhere in the navigation settings in my car to enable Navtraffic, so I know the software doesn't support XM Navtraffic.
Does anyone know if the Canadian TL Type-S has XM Navtraffic hardware in it?
garrettdigital (12-13-2014)
Thanks for the info. That's the first time I've read anyone actually trying and confirming that the connections are different which means that we definitely don't have the Navtraffic hardware.
@Nyordrms, have you tried other solutions besides the USA Spec?
I contacted iSimple support and they said I "should not need the PGHHD2C combination" (for navtraffic). They also said that "the normal Gateway (ISHD571) or connect ( ISHD651) should be fine."
It worries me a bit that they don't seem to be sure that they will work in my car. I'm hoping I can use the ISHD651 now that I have the answer to the Navtraffic question.
garrettdigital (12-15-2014)
Registered Bunny
I've resorted to modding the car, I'll install a Nexus 7 in the dash when summer comes to palliate to this issue.
Edit: Also iSimple aren't sure because they don't deal with Canadian TLs usually. If you look around the net most vendors aren't aware of the differences between US & CA TLs.
Well that is disappointing to hear that the ISHD651 was glitchy.
This is also the first time I've heard that there's no solution for text display in a Canadian TL.
Thanks Nyordrms and polobunny. Input from both of you has probably saved me from wasting some money.
I guess it's time to start looking at a completely different solution.
WDP Group!
yah I've pretty much given up on trying to find one that works in my car, i see numerous can tl's that have an simple in there car but most are 04-06,
so not sure if there is something different between them or what, but I've already wasted to much money trying a couple of them, not interested in "trying" another one, if i find one i wanna know it works 100%
DerrickW
11-15-2015 05:52 PM
