will i loose voice command or bluetooth - amp
i search and could not find the exact answer that i wanted but this is my question
i have a good sound music in my other which is for sale (mitsubishi eclipse 01), i want to install the sound system in my tl. i haven't done it yet cause i'm scare that i might loose the voice comand, the navi voice command, or bluetooth when someone call. usually you press the BT button to make a call, the music stop and only the bluetooth calling works. also when using the nav and playing sound, when is time to announce a street turn etc the navi turns off the front speakers and leave the back speaker with the music i was listening.
will i loose all that installing aftermark amp with speakers and a sub.
if that so i'll rather sell my equipments
tap after the factory amp and you won't loose anything. You will need a high-low converter to reduce the voltage of the signal unless your amp has high level inputs.
If you use a high-low converter, you'll leave the factory amp alone. I tapped in to the factory subwoofer, those + and - cables will go into the converter; from the converter, they'll go into the aftermarket amp as RCA's. The best part is, you'll still have factory controls of your aftermarket sub.
ITSJESTER
17
12-06-2018 02:29 AM
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-30-2015 09:43 AM
