Whining noise from stereo when started
Old Mar 28, 2018 | 07:39 PM
itsVSW's Avatar
https://youtu.be/1GsBxctzVI0
04 TL 6SPD NAV 140K
Can anyone shed some insight before I dive in? I've installed sound systems, but never encountered this issue.
Stock ELS. Whining/static noise only occurs under two conditions:
1: When the car is turned to on, but not started (momentarily)
2: When the car is started, AND the volume is turned up past zero. Pitch changes with RPM. However, whining volume doesn't change with stereo volume.
About three seconds after turning the car off, there's a click from the passenger floorboard, and the noise goes away.
Old Mar 28, 2018 | 08:24 PM
polobunny's Avatar
Registered Bunny
Is an mp3 player/cellphone plugged your tape adapter & also plugged in a charger, per chance? If so, get a ground loop isolator. ~15$.
Old Mar 28, 2018 | 08:26 PM
acuralongtime's Avatar
or problem with radio or amp
Old Mar 28, 2018 | 08:51 PM
itsVSW's Avatar
in the video, no. Nothing was plugged into the aux. And the sound has been present since purchase, one month ago. Searches lead me to believe it's the amp.
Old Mar 28, 2018 | 11:57 PM
polobunny's Avatar
Registered Bunny
I would agree with you in this case.
kingofbytes
Jul 26, 2015 11:40 AM
SlyAccord
4G TL Problems & Fixes
Sep 26, 2014 12:01 PM
-Z-
Dec 13, 2006 07:30 AM
sangamon
Aug 4, 2005 08:52 AM
Zerostatic
May 25, 2005 06:01 PM
