Where is the piezo sound emitter for the remote door lock located?
Not a noob
Those of you who have a 3rd gen TL with a working "beep" confirmation for activating the OEM security system by pushing lock on the key fob twice: where is the doohicky that makes the sound located?
I'd like to verify that the noise maker for the push-lock-twice function is operational—my 2007 TL-S won't beep, even though the "beep on" feature is selected via the MID.
Thanks in advance.
Thanks in advance.
1 Post
The sound emitter you are referring to is located under the front driver side light, basically right were the front bumper starts on the driver side. It may be not making a sound because you still have something open, its wired to a Ic that checks the car to make sure everything is closed, even having a window slightly open will cause it to not make a sound.. Check everything and then try again, if it still doesn't work it could be bad sensors on your doors or a bad ground wire on the speaker its self.
EGbeater (06-19-2012)
Not a noob
EGbeater (06-20-2012)
tman570
06-11-2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
