Where is the HFL Module located?
I have a 04 tl..the HFL is draining the hell out of my battery. It is now dying after 1 day of not running..use to be 3 days. I do not use the HFL and would like to disable.
Where is it located?
Thanks.
Thanks.
Dogmatic Dinosaur
In the roof console underneath the map lights.
Pop the sunroof switch off with a feeler guage and disconnect. Stick a few fingers up in the hole and pull. Disconnect. It has 4 8MM or 10MM bolts that hold the trim piece on. It is under there.
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
