What Friendly user program to use to burn DVD-A with Vista...?
Hi folks,
I tried to install the program that Abobeman did but it doesn't work with Windows Vista. Is there any EZ program to use to burn a DVD-A which is compatible with windows Vista.
Frank
Frank
The DVD-A Script Guy
http://www.microsoft.com/downloads/d...displaylang=en
You could also try Cirlinca DVD Audio Solo. www.cirlinca.com That's what I'd do.
Thanks Adobeman, but can you explain me step by step how to make a DVD-A because I do not really understand. There's like 2 programs needed to make a DVD-A...
Frank
Frank
coudl be an x64 vs x32 problem as well. vista doesnt play nice with 32bit usermode. and it seems more people are buyign 64bit altho all their apps are 32bit. from what ive seen wow32 needs some work.
check Adobeman's signature he has links to his program there and also the DIY is in there too.
Adobeman's one of the great guys we're grateful for in making our lives easier. I've used his prog. to make at least 25 DVDAs
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Programs you'll need:
1. Adobeman's non-gui (make sure you install it in C:\dvda dir)
2. CDEX (to convert mp3 files to wav as besweet program included in Adobeman's util is not perfect)
3. Burning program (to burn image file to a DVD-R)
and make sure you use a DVD-R (verbatims work perfectly) since the dvda play in our acura is picky
calrow
05-03-2017 10:21 PM
InFaMouSLink
11-11-2015 12:19 PM
SinCityTLX
55
10-11-2015 01:20 AM
joflewbyu2
10-08-2015 11:16 AM
