Unable to find place to input radio code
Old Jul 24, 2007 | 06:27 PM
Scooty's Avatar
8th Gear
I got my car back from the shop, apparently they disconnected the battery. When I got in and started, I noticed an input screen asking for a code. (which one I wasn't sure) so I entered the nav code, and the nav works. Unfortunately my stereo doesnt work because I can't find a way to input the radio code.
I have the radio code, just can't bring up the screen to input this code. I disconnected the neg battery cable again, and went throught the same thing. I'm on my 4th error. ( I believe I have 10 tries?)
If anyone knows how I can input my radio code, I would really appreciate. Driving home in the morning after working 12 hours nights gets a little boring. I like to crank up some Van Halen ( Mean Street) when I start to doze off.
2005 TL w/nav
Thanks guys.
Old Jul 24, 2007 | 06:43 PM
Porkipine's Avatar
'07 NBP TL
This is for an 2007 TL but should be the same for you too.
The radio code is inputted from the 1-6 button (the actual buttons you use to change CD and stuff). There should be a display next to your clock that will have an astrik come on everytime you push a button. i don't think there is an enter button. It should just work after you push in all the digits.
The one on the navi screen with then number pad is for your navi code. Hope this helps. gl
Old Jul 24, 2007 | 07:33 PM
6MTUA5's Avatar
No He Can't
Use the 1-6 buttons for the changer/radio
Old Jul 24, 2007 | 07:50 PM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
If you also have navi, there is a different code. That one will appear in the navi screen and you use the touchpad to input the numbers.
Tell us you got it done.
Old Jul 24, 2007 | 07:58 PM
Hardtimes's Avatar
you might know this but i saw it happen the other day. if you don't turn on the power for the radio, inputting the code will not work.. if the navi already works. this might be your problem...
Old Jul 25, 2007 | 01:17 AM
Scooty's Avatar
8th Gear
Thanks. So what your saying is I can input the 5 digit code using the 1-6 buttons?
One of the code numbers I believe (I'm at work right now) is a 7.
I did hold in the 1&6 button at the same time yesterday and that simply generates an error.
Old Jul 25, 2007 | 01:59 AM
MR1's Avatar
MR1
And well it should have
If it requested a 7 then that's the Navi Code you are after and it goes on the touch screen as described above. Radio codes are digits 1-6.
Any and all numbers for the codes are tapped one at a time. Good luck.
Old Jul 25, 2007 | 10:50 AM
Porkipine's Avatar
'07 NBP TL
yup. If there is a 7, then its probably the navi code.
my navi code is 4 digits. my radio code is 5 digits. once again, this is a 07 TL.
how many digits does your code have?
Old Jul 25, 2007 | 12:32 PM
Scooty's Avatar
8th Gear
I just checked the radio code, it's a 5 digit all numbers 6 or below.
Anyway, back to my original question. How do I bring up the screen to input this said code.
I have already generated 6 error codes and am getting nervous.
If you could walk me through the process, that would be awesome.
Old Jul 25, 2007 | 12:38 PM
Scooty's Avatar
8th Gear
All I see right now is the word "CODE" Actually, the letters CO. When I start pressing buttons, it completes the word CODE, and then gives an error message "error5" (the number increases as I goof up.)
Old Jul 25, 2007 | 12:46 PM
6MTUA5's Avatar
No He Can't
Enter in some numbers until you hear it beep and tell you that you have made an error. After that, it is reset and you can enter in the code from the beginning.
The furst number should bring up the C second O third D and fourth digit should bring up the E. After that, push the last button and it should beep and tell you that you've entered it correct.
IF you enter in the code wrong too many times, it will make you have the car running for a whole hour (non-stop) to be able to try and re enter the code
Hope this helps
Old Jul 25, 2007 | 12:52 PM
VmtSquad's Avatar
"Advance"
KShuckDeve is totally right!, its a 5 digits code, so C-O-D-E + the fifth one...for me its a 3 error chances, if you reach the 3rd error, disconnect the battery for 5-10min. AND TRY AGAIN! With the right CODE!
Concentrate, you must be mixing between navi and Hunit code....good luck!
Old Jul 25, 2007 | 04:57 PM
Scooty's Avatar
8th Gear
OKAY! I got it. Thanks to everyone for your replies. Nice to have tunes again.
oo7spy
Jun 19, 2023 12:48 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
handsom-hustla
Nov 13, 2015 05:04 PM
ibGTV
Sep 28, 2015 03:40 AM
PortlandRL
Sep 14, 2015 12:01 PM
