Type S stereo watts output??
08 WDP TL-S
Hey guys..
How much is the Type S stereo watts output?is it only 225 watts with 8 speakers?
if its 225 watts only,which is less than a 4G TL-P...correct me if i m wrong guys
08 WDP TL-S
No highs, no lows, must be bose
Wattage really doesn't matter as far as loudness or a good system is concerned. The TL's stereo gets moderately loud and then sort of levels off in terms of loudness. After about 32 it starts getting a bit distorted. If you want louder your probably going to need new speakers and amplifiers.
That sums up Bose. Probably the all time best marketing and the worst product. The HT guys won't even let you say that name around them. Overpriced and no performance.
As to the total wattage, it's not much. I have no idea how they rate the system and if they adhere to the standard but the claimed 225w is pushing it. If I remember right, the stock 6.5" have a max power rating of 15 or 25w stamped on the back of the system. Most factory speakers are more efficient than aftermarket so adding aftermarket speakers without doing an amp will result in less SPL.
I've only recently learned the value in speaker efficiency and why they have the potential to sound better than less efficient speakers. My two efficient 15s combined require half the power that I was running to a single 12" before.
There's a lot more to output than the factory rated total watts. You have speaker efficiency, total speakers, and the power ratings are usually very optimistic. If the TL actually put out 100w to the sub, I could run my 15s off the factory amp but that's not happening. Anyone who has added even a small sub to the factory amp has had major output issues.
I totally agree that The FM quality is horrible, even near the city I barely get a good signal and the sq isn't great.
Anyway to make the FM signal stronger or clearer as I listen to the radio a lot?
sockr1
10-01-2015 01:31 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
