Two different Issues : / Help
Old 12-13-2011 | 05:27 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
So I been noticing a small feedback noise when i turn the radio on or when i have a cd on pause.. which i can hear the whole time .. ask my friend believe to be a loose ground wire does that sound right and where would i look for it??? and on my Steeringwheel when i the press the volume up button at times would restart song on cd or change radio station when i have on radio.. and any easy fixes to this ????
Old 12-13-2011 | 08:41 PM
Trunk Monkey's Avatar
Coolest A-zine Member
...kinda lost here, but what does the noise sound like?? Humming? Is it whine and increase/decrease with speed? I see you have an Isimple..noise with that unit on and playing?
Do you have any aftermarket amps?
Old 12-14-2011 | 03:27 AM
thizzx3w's Avatar
8th Gear
if you do have an aftermarket amp, are your speaker wires and power wire on the same side?
Old 12-14-2011 | 11:02 AM
JD TL-S's Avatar
Any grounds must be tight. If you have an aftermarket amp, make sure you ground it as close to the amp as possible with a clean connection to steel.
Merry Christmas
cipdagr3at (12-17-2011)
Old 12-14-2011 | 03:57 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Yea its more like a low frequency noise.. it does speed up when i drive with no music playing but when i do play music i can hear in the background is the best way i can put it???
Old 12-14-2011 | 04:02 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Yes, i do have an aftermarket amp hooked with my 10' sub but nothing connected with the stock speakers...
snorf
11-04-2019 07:44 AM
Kres43
1G RDX (2007-2012)
10-03-2015 08:16 PM
Frathora
09-29-2015 12:29 AM
tristann616
1/2G MDX (2001-2013)
09-23-2015 12:40 AM
carz0159
09-20-2015 07:11 PM
Quick Reply: Two different Issues : / Help
