TL Navigation help
you can buy the parts for it, but in the end, the headache, labor and part will cost more than the car with navi from the factory. Search for nav conversion on the boards, you should get quite a few threads.
not really you would have to change the dash harness all the plugs are in different spots and you would still have to run the wiring for the gps antenna which is part of the body harness
Welcome aboard onlyacura.
This question has been discussed on here on many occasions. There are always debate by members on whether its worth it or not. It is possible, but is it worth it to you?
If you want more details on this, check out the 3G TL Audio & Electronics FAQ and also try a search with the keyword conversion.
Please continue the discussion in any of the previous threads. Thank you.
dirleton
08-06-2024 08:19 PM
navtool.com
31
11-16-2015 08:30 PM
TLguy42
09-26-2015 11:27 AM
