System gurus chime in
Old May 21, 2012 | 12:08 AM
slammedon19'''s Avatar
ok i have 2 rockford p3s 12s a rockford t1000 mono amp, rockford prime 400 for some memphis components, an lc6i, rockford cap 2farad.i what to hook it up pre amp any thing else i need i want this thing to sound good
Old May 21, 2012 | 08:54 AM
rich20730's Avatar
You can only go post amp with the LC6i
Old May 21, 2012 | 10:57 AM
what do ineed
so what do ineed to go preamp
Old May 21, 2012 | 11:08 AM
Trunk Monkey's Avatar
Coolest A-zine Member
I'd find an Audiocontrol Matrix or a Rockford Fosgate BLD.
Old May 22, 2012 | 01:09 AM
ok
does the rockford bld convert speaker wire into jacks like the lc6i or do i use them both
Old May 22, 2012 | 08:09 AM
rich20730's Avatar
The BLD only has RCA inputs. You wouldn't use the LC6i at all if you went preamp. You would splice or solder RCA ends onto the head unit outputs or use something like this: http://www.sonicelectronix.com/item_...SL-09ZISL.html
Old May 22, 2012 | 11:01 AM
jda123's Avatar
Dogmatic Dinosaur
The BLD has line level inputs too.
It is single channel, but the single front channel is all that I use for the fronts and sub.
Old May 22, 2012 | 11:19 AM
rich20730's Avatar
Ha. You're right. I should really know better since I have one
Old May 22, 2012 | 09:08 PM
audio control
i called the people from audiocontrol and they said the lc6i has a built in line driver and that i can go preamp
Old May 22, 2012 | 10:33 PM
rich20730's Avatar
That's news to me. Let me know how it works out.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
