Suggestions: Quality system under a $G
Suggestions
Was thinking of replacing the factory sub with a free air sub if it would mount right. Don't want the congested trunk look so I was thinking this would be a good option. Also thought about removing the spare and customizing the trunk floor. IDK at this point don't want anything too crazy but a really clean look and sound. Suggestions anyone???? any and all feedback is welcome
THX
THX
Just for fun, here is an idea. Under $1G is tough, although DIYMAer's would argue that.
Keep stock HU - No reason for aftermarket, unless you don't have nav system and want one.
Keep stock amp to power your center channel and, if you want, your rear speakers. 95%+ of the car audiophiles I know do not run rear fill.
Purchase aftermarket amp to power front mids, tweets, and at a future date a sub.
Purchase Sound processing/EQ: Run HU to stock and aftermarket amps to sound processing unit. Then to either cross-over (passive system) OR directly to the speakers (active system)
Mids/Tweets: There are so many combos. Having clean power and EQ/sound processing as a foundation will make any mid/tweet you purchase sound better then a high $$ mid/tweet without clean power and EQ
Accessories: Dynamat/Sound Deadening, wiring, fittings, etc... People forget about this in budgeting. Sound deading alone can add up quickly.
After a quick search, here's a quality, low cost amp, and sound-processing unit...
Amp
650 AG ZAPCO AMP 6 Channels - $300-$350
I would use channels 1-4 to power the front mids and tweets and bridge channels 5 and 6 to power a sub sometime in the future.
http://cgi.ebay.com/Zapco-AG-650-6CH...4#ht_720wt_683
Processing/Tuning
Rockford 360.2 w/ Remote Blue Tooth Enabled Tuning - $200.00 - $250
http://cgi.ebay.com/Rockford-Fosgate...4#ht_533wt_909
Good luck with your system
THX all that responded,
Yeah I would do it myself unless I found somebody in the area that wouldn't mind helpin on a weekend. I've installed b4 I just want this to look very stock ya know?!?
If you could PM me the price and specson the box (L, W, H wtc...) that would be dope. preciate it homie.
Whew, really appreciate the info my dude. Really gave me some good momentum. Is that a pic of ur trunk.. looks fresh, real clean.
I will let u guys know what the verdict is once I get it all together. Thanks again
TOS
TOS
That is my truck previous to existing. I now have three amps (Zapco) and 2 12'' Subs (DIYMA) and a three way front stage with SEAS componnents.
i just put a 10" arch audio sub w/ jl 250w amp in a 1cu ft enclosed box in the trunk. ran the power wire from battery(4guage) and simply cut the wire from the rear stock sub and spliced it with a good rca cable and ran it to the amp. it was cheap (260$-amp 180$-sub 80$-4g wiring kit 60$-box) and sounds absolutely amazin. pounds but still has great balance. plus can control the sub from headunit. just make sure to amp with signal sensing so it shuts off.
rcs86
08-02-2016 06:52 PM
SinCityTLX
20
10-19-2015 11:23 AM
maharajamd
Console & Computer Gaming
09-24-2015 03:31 PM
