Suggestions for New Speakers
My passenger door speaker is sounding really bad especially at higher volume and certain frequencies. It isn't dead yet, but might as well be. Anyone on here with experience in replacing the TL's speakers: What is your set-up/ what do you recommend? I am considering replacing the two door speakers, two tweeters, and center speaker as well, but do not necessarily have to. I would even be okay with getting OEM speakers and calling it a day.
I want the best bang for your buck. No explicit budget, but don't want to lavishly spend. Any and all suggestions are appreciated.
Thanks in advanced!
(P.S. - I have researched Crutchfield, but not really sure what combination of speakers to go with if I replace everything in the front of the car (easiest to modify). Really just want to here people's opinions on their set-ups)
Thanks in advanced!
are you open to an aftermarket amp for the speakers? if so i highly highly recommend image dynamics ctx65cs. great sound for a great price.
i also have a set of jbl front components that can probably work with the oem amp if you're interested in them (complete plug and play speakers and tweeters). i got them to replace my oem ones and then i found a great deal on the ID speakers so i switched them out.
Also, I am interested in your JBL components. Can you tell me more about them?
jbl: they are jbl gto608c components and are pretty much plug and play (just some minor work to make tweeters look oem but really easy...basically glue the tweeters on the underside of the oem grill). i've thought about running these as my rear speakers but don't feel like doing all that work again haha
i can also include plug and play adapters to plug into the door connectors (usually $5) and i can also include my modified oem white plastic "buckets" to make them plug and play in the doors. if not, no worries! just trying to help you out and give you options.
I just had a set of JBL GX600C component speakers put in my car. They were like $120 at Best Buy (can probably find them a little cheaper on Amazon) and they sound pretty good! They were plug and play, so no significant modifications needed. The sound you get from these are very balanced, no harsh highs or anything like that. I may post a review on them in the coming days for these, so people can get an idea of what to expect with aftermarket speakers on the factory amp.
Is there a max mounting depth?
I was looking at Crutchfield.Com and they said there's only one pair of speakers that would fit my 08 TL. Is there max mounting depth or that's just the only speaker they have that would fit?
When I was first shopping for speakers I checked Crutchfield and thought the same. Most 6.5" component speakers should fit with little to no modification. If you plan to run the speakers without an aftermarket amp make sure they are rated at 2 ohms, if they're 4 ohms volume will be lost.
there are a few that fit into the oem locations. i know the JBL gto608c's fit in the stock location and they have a 2 1/16" mounting depth. Anything deeper than that and you may need spacers.
mossman77
23
06-29-2016 11:44 AM
jflader59
06-20-2016 07:45 PM
Pandion
05-09-2016 04:23 PM
SurfingScotty
01-17-2016 09:03 AM
