Subwoofer Wiring Help!
Before anything I would like to let everyone know that I am a complete newbie at audio wiring :tomato:
I have a 12 alpine type R sub and an alpine amp, MRD-M300 and I need help wiring it. I would like to keep everything stock, just add a sub and amp. Also I have read when doing this will the center channel (nav) speaker still work? Will my new amp replace the old one or can I just keep a separate one for the sub?Thanks :thumbsup: |
Originally Posted by AcUraTL125435
(Post 13912831)
I have a 12 alpine type R sub and an alpine amp, MRD-M300 and I need help wiring it. I would like to keep everything stock, just add a sub and amp. Also I have read when doing this will the center channel (nav) speaker still work? Will my new amp replace the old one or can I just keep a separate one for the sub?Thanks :thumbsup: Been done numerous times numerous different ways :toocool: |
disconnect OEM sub take those wires and add a LOC then connect to your amp. Run new power and ground to your amp. May need a signal wire to turn on amp if it doesnt automatically sense the input. If your amp takes speaker level inputs you could do away with the LOC.
but yes! search is your friend. use google search with acurazine in search, search engine on this site is useless. |
Originally Posted by pohljm
(Post 13912980)
(Post 13912980)
I do not see how it would. The other speakers, if anything, will experience a cleaner signal from the stock amp with the stock sub disconnected because the power supply will not have to work as hard. With my stock sub disconnected I could turn the volume all the way up with bass on 6 with little distortion. Ido not recommend keeping it like that for any length of time though as it is the distortion from the amp signal which will harm speakers in most cases.
