Subwoofer box
trying to find a subwoofer box that fits in the left side of the trunk that holds a 12in sub ...its like a stealth box i seen it on here but cant find it ...can someone post a link were i can buy it ...thanks
unclad4 sells them:
you can search on here to find lots of links There are some on ebay: Search for "acura tl 12 subwoofer" Audio Integrations also has one: http://www.audiointegrations.net/cat...75/8253904.htm |
http://wickedcas.com/product.php?pro...&cat=12&page=1
I got a better deal when I called them directly. I've run mine for about 3 years with a 12w6v2 and I love it. Edit: on 2nd look... that audio integrations uses oem carpet... that's a plus! |
That enclosure from audio integrations does look really nice but its only 16lbs compared to the wicked C.A.S 25lbs. I'm wondering about the sturdiness and quality between these two. And also wondering how good the sub sounds in enclosures like these...is there a sacrifice?? i want my sub to sound as good as possible... how loud doesnt matter. I have a Boston G5 12"
ok this is kinda off topic.. but how do u plan on running ur amp? mono amp or are ugna hook up ur speakers along with it?
I have an audio integrations box with a 12" FI Q in it running 2.9ish ohms at 1300W off of a T1500-1bdcp. It is sturdy enough to make coffee jump out of a cup and make the rear view mirror nosedive downward after about 3 beats. It will take all that our stock alternators can handle IMO.
It sounds great too... all that I did was remove the weight from the trunk, put 4 screws into the license plate, remove the rear sub and take care of the rattles in the rear deck. This is my first 1000+ watt system without dynamat and I probably will not put it in. The SQ depends on the sub - any good sealed enclosure (fiberglass or otherwise) that is solidly built should handle a sub made for the volume. I really like FI Qs because they hammer and sound great while doing it. I put mine in over the trunk liner - not sure what I think about it yet - but in most ways it looks like it was put in there from the factory. |
Edit by Admin Ron A: No selling in this forum.
Do you still have them available
Originally Posted by Fezteh
(Post 14910728)
The post is almost 3 years old and he hasn't logged in since 08-22-2012 so he will probably not see your post. I deleted your duplicate post since one post is usually enough. |
