Speaker Buzz
Speaker Buzz
Has anyone else had any problems with speakers buzzing? My right rear speaker sounds like a bee. Not bad at higher volumes, but down low it's pretty noticeable. My dealer already replaced the speaker and the entire radio. No help. I've been living with it but would really like to get it fixed.
05 C230K & 09 135i 6MT
Maybe they need to look at the amps. They have to fix it, it's under warranty.
My 02 TL's Bose speakers started buzzing at one point, and they threw parts at it. It took replacing the entire system (headunit, both amps, equalizer, and all speakers) to solve it. But that's what they did because they had to.
'04 6mt Pearl
While playing some piano music on the CD hold your hand to the speaker and press around the grille to determine if it's a mechanical rattle rather than a blown speaker.
So far I think they have pretty much replaced everything, speaker, radio, amp. The buzz is definitely something electronic and not a mechanical thing. Someone mentioned that it may be a problem with a ground.
2004 SSM/EB/5AT/Navi/RSB
Does it buzz all the time or only when the head unit is on? Does it do it regardless of source (ie cassette, CD, radio, etc.)? Does the buzz change volume when you change the volume knob?
It pretty much buzzes all the time, no matter what the source. At higher volumes you really can't notice it. Between songs, or at low points in songs though you can tell it's there.can definitely hear it.
BLM,
Did you ever get the buzz fixed? My 04 TL is doing the exact same thing. Would love to know what the fix is. It's driving my wife nuts.
Thanks,
Bob
Thanks,
Bob
'13 Hyundai Sonata
It might be one of the wires that go to the speaker, but def get that fixed.
I don't have those kind of speaker problems because all of those speaker problems were replaced.
Originally Posted by bhaubold
BLM,
Thanks,
Bob
Thanks,
Bob
Bob,
I did. It took about nine times but they finally just traced all the wires between the radio and the speakers and found one that was pinched, I think under the dash. It was pretty frustrating.
Speaker buzzes are usually due to malfunctioning ANC (Active Noise cancellation) circuit which resides in the head unit. But it could also be some issues with the wiring harness, interference from other devices or with the sound pick-up microphones which feed the ANC circuit.
Took the car to the dealer. They fix it, even though the car was out of warrenty. (55000 miles). They replaced the amplifier and everything seems good.
Thanks for all your replys,
Bob
Bob
i heard some people with the new Si civics stating that re-routing the ground wire of the amplifier fixes they're buzzing noise....i tried it today on a customer car...no luck...ill turn off the ANC tomorrow and see if it does anything...i dotn think any1 has replaced the amp though...
dainmezron
10-16-2015 06:56 PM
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
