Remote Start Stock Remote??
Old Nov 16, 2007 | 04:36 PM
3pt2TypeS's Avatar
I was in the market for getting a remote start installed and i want to keep the stock remotes for reasons such as stock look memory seats truck pop and the such.....i dunno if anyone has done this i read a few threads and people say that certain alarms can be added onto ur stock keyless.....but didnt make any mention of what remote starts they would be any suggestions i havent bought a remote start yet and i have an 04 TL auto tranny of course
Old Nov 16, 2007 | 05:04 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
^^^If this is a possibility, I would be interested in this as well.
Old Nov 16, 2007 | 05:25 PM
rbf351's Avatar
Registered User
i did it on my 05 TL, so yes it can be done
Old Nov 16, 2007 | 05:28 PM
csmeance's Avatar
I read in the RL forums that one guy put in a remote start and had it hooked up to the lock button, so if it were pressed twice, the beeping noise would activate it.
Old Nov 16, 2007 | 05:41 PM
uncald4's Avatar
Former Sponsor
It is possible. BUT... as soon as you remote start your car the remotes go dead. Did you ever notice that when you're car is running you can't lock or unlock your doors? If you use your OEM keyfob to remote start your car, you'll have to unlock the door with your key.
The older Acura TL, CL and RL had an actual alarm module under the passenger seat. With some rewiring you could trick the alarm module into thinking that the car is not running yet. This let the remotes lock and unlock even after you remote started the car. All newer Acura/ Honda cars have multiplexed security systems. This means that it's integrated into multiple modules throughout the car. No way to trick it.
Old Nov 16, 2007 | 07:01 PM
TL_S_Driver's Avatar
here's the problem with this approach. the OEM keyfob doesn't have any range. so even if you do get it activated successfully which i don't believe would be the problem. you still need to be relatively close which almost eliminates the benefit. i want to be able to activate it from inside my home if it's parked street side and have it be all nice and cozy when i step outside a few minutes later.
Old Nov 16, 2007 | 07:13 PM
3pt2TypeS's Avatar
ok well range isnt too bad for me i dont mind going to my front door to remote start it....heres a novel idea tho......what if u were to program it to i dunno say hit unlock twice and it starts the car then u dont have to worry about unlocking it.....ooorr if u could disable the panic feature and have that as a dedicated remote start button....cuz well ive never ever ever used that but these are just ideas.....i wish there was someway to have aftermarket keyfobs do memory seats cuz thats all i really care about
Old Nov 16, 2007 | 07:30 PM
rbf351's Avatar
Registered User
actually the TL's keyless entry module is still the same crappy 3 wire box (power/ground/signal)
Old Nov 16, 2007 | 07:44 PM
BENDER08's Avatar
Back in a TL again.
yes yes and yes
You can have remote start with your stock keyfob the sequence goes normally like this lock unlock lock and it will start or hit the lock button 3-4 times
the range not a problem i always use the remote under chin and i swear by it it triples the distance for me.
and ill find out what one i have and let you know
Old Nov 16, 2007 | 11:07 PM
timmahh's Avatar
it's me, Alan Rickman.
the typical module activates off the third pulse lock; unlocking it = hey my car is running come get it.
Old Nov 17, 2007 | 10:50 AM
rbf351's Avatar
Registered User
almost all made by DEI can be changed to work on the 3rd lock pulse
Old Nov 17, 2007 | 11:12 AM
TwinTurbo335's Avatar
So could a 2003 TL-S be able to do this? I wouldn't mind having a remote start on a stock remote. How would this mod be possible?
Old Nov 17, 2007 | 11:16 AM
timmahh's Avatar
yeah thats why I said that lol
Old Nov 17, 2007 | 11:43 AM
99GrnTLP's Avatar
I understand why u would want to intergrate the remote start on the factory remote. Just keep in mind that the aftermarket remote has atleast twice the range and u also have the option of getting a two way remote to receive conformation that your car properly started ect....
Old Nov 17, 2007 | 02:28 PM
aSPECtL06's Avatar
I agree, the aftermarket remotes do increase the range and if I were to get a remote start, I wouldn't use the stock remote. The range of my stock remote has decreased drastically and I don't know what the reason is. My question is, somebody said that they wouldn't mind standing in front of the car to turn it on...does that not defeat the purpose of the remote start?
I'm interested in getting one too but which one would be a good buy? Clifford maybe?
Old Nov 17, 2007 | 04:09 PM
3pt2TypeS's Avatar
well theres two reasons why i dont mind standing in front of it and remote starting it bc A. I live in South Jersey (Home of Camden, NJ) i wouldnt leave my keys in my ignition in a convent around here.....and B. when i say in front of it i mean like 10 feet away.....from my front door i.e. warmth of the house
Old Nov 17, 2007 | 06:00 PM
aSPECtL06's Avatar
True about the South Jersey part... ...what systems were you looking to get?
Old Nov 17, 2007 | 07:37 PM
custom built's Avatar
compustar makes one that is programable to do all of the things you want. the only issue you will have is unlock but you could just put your key in the door and unlock it. as for theft if its running, not happnin. if you step on the brake it will shut down. they might steal everything in your car but not your car
Old Nov 17, 2007 | 08:28 PM
uncald4's Avatar
Former Sponsor
CompuStar is a great alarm/remote start. For some reason my customers hate them. I've got a BMW 330CI in my shop right now that I'm pulling one out of. Most people claim that they "have to have it" because it's the only fail safe remote start for manual transmissions. But it's such a pain in the ass that the convenience factor is gone.
Have we killed the remote start with OEM keyfob idea yet? Range is poop. You need to unlock your door manually.
Old Nov 17, 2007 | 08:53 PM
nfnsquared's Avatar
what unlock issue are you talking about?
Old Nov 17, 2007 | 09:06 PM
uncald4's Avatar
Former Sponsor
You factory keyfobs go dead when the car is started. You can remote start the car with the OEM fob but you'd have to unlock the car with the key.
Old Nov 17, 2007 | 09:39 PM
nfnsquared's Avatar
No, he made it sound like there was an unlock issue with Compustar. The compustar remote will autostart and unlock your car, but you'll loose seat memory, window roll down, etc. (unless you add additional relays)
Old Nov 19, 2007 | 10:31 AM
3pt2TypeS's Avatar
i dunno what system i want i wanna do it up and get the Viper 990 or whatever it is the full alarm but honestly all i really want is remote start and for an extra 200 i dont think ill use 1/8 of the extra shit that it comes with
Old Nov 19, 2007 | 02:55 PM
rbf351's Avatar
Registered User
your wrong. i've done it myself. if you know how to properly wire it up the keyfob will still work when the remote start is activated.
it very simple to do, and is a matter of cutting 1 wire
Old Nov 19, 2007 | 03:07 PM
NTP66's Avatar
2024 TLX Type-S
Are you talking about a remote starter that uses the factory keyfob to both start the car, and unlock the doors? If so, I've been trying to find out exactly how to do that. Care to shed some light as to how that's done and what is needed?
Old Nov 19, 2007 | 03:15 PM
rbf351's Avatar
Registered User
yes it uses the factory keyfob to remote start the car, and also lets the stock keyfob functions work.
when you remotestart the car you can lock and unlock the car while it's running. if the car is running with the key in the ignition it will not lock/unlock via the keyfob, just as it does without the remotestart module
all i used was the valet 56x model. forgot exactly which one it was, and not gonna tear my car apart to get to it. the stock remote box is 3 wires, power/ground/signal. you use the signal wire.
Old Nov 19, 2007 | 07:41 PM
uncald4's Avatar
Former Sponsor
You've definitely got it figured out then. Would you mind sharing what wire you cut? I gave up years ago. We would love you and hug you and call you George!
Old Nov 19, 2007 | 08:07 PM
rbf351's Avatar
Registered User
I prefer Rob
i did it on 2 honda/acuras (05 Civic, and 05 TL) if i find my old wiring schematics for when i did the install i'll read the notes i wrote, and post them up here.
Old Nov 19, 2007 | 08:11 PM
i can figure it out just tell me where the factory remote box is
Old Nov 19, 2007 | 08:17 PM
rbf351's Avatar
Registered User
there is nothing to figure out, i already did it, and remember how i did it. Now i'm just deciding if i should share or not
Old Nov 19, 2007 | 08:28 PM
uncald4's Avatar
Former Sponsor
I prefer Rob
In older Honda/Acura's you cut the ignition input wire to the security module. One side of the cut wire would go to the ignition output of the remote start and one would go to the ignition input of the remote start. On the older Acura's this wire was yellow at the security module.
Old Nov 19, 2007 | 10:47 PM
just tell us man !! i want to do this to my car..
Old Nov 28, 2007 | 02:37 PM
nalek's Avatar
+1
Old Nov 28, 2007 | 03:03 PM
ITL's Avatar
ITL
I do my own work.
+2
Old Nov 28, 2007 | 09:34 PM
glad you figured it out. glad your on a forum to help yet dont. forget it . hey it can be done guys all you have to do is figure it out on your own. RIGHT BACK TO WHERE WE STARTED.
Old Nov 28, 2007 | 09:38 PM
LOL!.. he just want to be the only one to do that to his car.. haha
Old Nov 28, 2007 | 10:16 PM
BrandonClaps's Avatar
this is how rbf351 is....he was the same way on clubsi.com
Old Nov 28, 2007 | 10:34 PM
BOOO!! not helping a fellow acurazine member out!
Old Nov 28, 2007 | 11:09 PM
Chris 07 Type S's Avatar
He is the definition of the word "dolt".
Old Nov 28, 2007 | 11:53 PM
+3
