Rattle by lights
Rattle by lights
not sure if anyone had this problem but if so hoe do u get rid of the rattle by the back plates?? that space there rattles even with dynamat on backmof the plate
It prolly is the plate or the frame around the plate. remove frame from around plate. also wedge some resilient material between plate and trunk lid
Westside_TL (03-25-2012)
I am talking about the frame that goes around your actual license plate. If you remove your license plate then you can remove the frame around it. Make sure you are securing the plate with all the screws possible.
mada51589
05-03-2022 08:54 PM
marcelft
07-10-2018 06:17 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
