Radio cover
Radio cover
Hi all,
Can somebody chime in on how to remove the radio front cover off? I've gone as far as getting the bottom part and both sides out, but I couldn't get the top part off. Top side is VERY tight and I don't want to break it. The cover is just clip on on all four sides. Maybe there's another way to take the top side off??
I want confirm this from any acurazinian before I continue.
Thanks!
Thanks!
Not sure, as I have yet to tear it apart to replace. All of the other bulbs have the blue "condoms" to cast the greenish glow (blue + yellow=green).
You might be able to put a separate LED behind each window, but that would be crazy bright, IMO.
There is a series of articles in the 3G Garage detailing what I and other members have done with LEDs. Search for the DIY series by DeathMetal for lots of info. Here is a taste:
yes, when you turn the radio on or off. no problem turning the knobs, just pushing the knobs in have clicking noise now unlike the OEM feel before (no clicking noise).
i think the knobs are just now sitting in the right position. maybe a bit more pushed in and the end of the knob is hitting the white plastic piece behind it. but how to adjust them to sit properly?
Not sure about that one. Mine went back together fine. I do have to remove it again to install the LED board---I plan on getting to that in the next month or so and will let you know.
In the meantime, you can PM Dan (DeathMetal) or madsiick to see if they have any input. I know both of them have had their radio faces off in the past.
dirleton
08-06-2024 08:19 PM
InFaMouSLink
10-27-2015 06:52 PM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
