Radio Code Not Working??
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Hey everyone, so I just finished installing my amp and subs into my '05 TL today and I found out using the search on how to put the codes in for the Navi and the Radio... well my problem is that my Radio code that came with my car isn't working. I'm on error 7 of 10 so I don't want to do it too many more times so that I have to unplug my battery again. Is there a manual override code? Has anyone else had this problem and resolved it? Otherwise I'm going to have to call Acura and that can be such a pain. Any help is appreciated. Thanks!
05 TL NBP 6spd S front
Are you trying to input the Radio Code or the navi code.
For the Navi you use the buttons on your screen 4 digit pin and for the radio you use the numbers that are in the CD changer a 6 digit pin.
In some cars and My they have a copy of the radio & anvi code on the left side of the club compartment.
good luck
good luck
Update:
So I called Acura. The problem was that at some point the radio was updated when it was brought to Acura for service from the original owner. I'm the second owner so I only have what they guy I bought the car off of gave me. My Navi Code works fine, it was just that the Radio code I had was for the original radio. I called up Acura and they helped me out to get my Radio Serial number so they could look up the code for it. Took all of 5 minutes.
mada51589
05-03-2022 08:54 PM
handsom-hustla
11-13-2015 05:04 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
