Quick Place to Tap Battery Power
I just took out the Movies2Go system from our 08 TL with navi. Come to find out, there is not an audio/video output on that system. Glad I got it from Crutchfield as they will let me return it. All their catalogs said it had a/v out to run to an additional monitor but I called Audiovox and they said there was no way to tap in to the video to put one in.
Anyway, I made an aluminum bracket to just hold a monitor up against the headrests to see how I like that option. I will be using a Vizualogic DVD player and I need a quick place to tap battery/constant power. I need something quick just to see if I will like this setup or not. The power is for the monitor's brain box which will be under the passenger's seat. Any quick place in that area to tap it? The DVD player and the monitor need acc. power but the DVD player has a cig plug that I can use and tap the monitor's acc and ground to it. Just need battery power.
Thanks.
Thanks.
mada51589
05-03-2022 08:54 PM
