Quick iSimple Question regarding Acura & Honda
4G Acura TL SH-AWD/TECH
Frankly, looking to put an iSimple unit into my 04 TL w/ nav.
The unit I am looking for has the seller describing it as "coming out of a 2007 honda Odyssey". He doesn't know any more information such as model # and what not.
My question is, would I be able to install this same unit into my 2004 TL?
Also, I would be using with iPhone 4s'
here is a picture of item seller posted:
That should work. I think that the difference between the 04-06 TL and newer was just the connector and the HD1 is the one you want (which is in the pic). You should check to make sure though. Also, you need the connector that goes from the unit to the iPhone which isn't in the pic.
FYI: Some people have picked up units from Amazon for around $40 so you might want to search for that thread.
