Power Kit for Acura TL 2004 install...
Progress is being made on my install, I've gathered my JL sub, 2 JL amps and 2 sets of JL components as well as a 1 farad cap for the car. Can anyone suggest maybe a kit to get as far as the power goes? I'm thinking I will need a power wire w/ a fuse (not sure on what gauge to get) then that goes to the back to a power block to split off to the two amps. Also what speaker wire gauges should I use? This is my setup...planning to keep the stock head unit.
http://www.jlaudio.com/ho112r-w6v2-c...-systems-93132
http://www.jlaudio.com/car-audio-evolution-c5 x2 sets
http://www.jlaudio.com/500-1v2-car-a...plifiers-98080
http://www.jlaudio.com/xd400-4-car-a...plifiers-98261
Would a 20ft run of power wire make it from battery to the trunk if I run from battery to the middle grommet in the firewall and run down the drivers side? Has anyone tried running the power wire straight down the middle of the car?
monoprice
knuconcept
knuconcept
thedeadmanx (01-30-2013)
AndrewS
19
03-14-2024 06:59 PM
mike from annapolis
05-07-2017 08:21 PM
Zonian22
11-14-2015 01:20 PM
nuldabz
09-03-2015 05:49 PM
