Please help, radio does not turn on
Where Did My Garage Go?!!
Tried pulling the fuse, and disconnecting the battery....the Anti-Theft light blinks but the radio will not turn on at all.....can any of the fuses besides the radio fuse cause this (like the ACC?)
Any solution to this?!?!
Did you try entering the audio code? When the car battery dies or is disconnected sometimes you need to enter the navigation and aduo codes. I first thought these were the same as the user PIN that can be entered but they're not. In one of the booklets that came with the car, the audio and nav (if applicable) 5 digit codes should be written in. If you don't have them, I would give the dealer a call and see if they can pull them for you. Hope this helps.
rockyboy
08-04-2024 11:35 AM
handsom-hustla
11-13-2015 06:04 PM
