Pics of the new USASpec PA11-HON2Y NOW w/ included XM y-cable
Well I just got my updated USASpec PA11-HON2Y.
To my surprise it seems to have a Y-adapter built right in to the cable. From everything on here, with the previous version you needed to buy the y-cable seperately (which I already had). So that must be at least part of the reason for the new "Y" in the model number, besides the compatibility fixes to issues everyone on here has had. Here is the package. http://i.pbase.com/g2/82/88482/3/65646504.Hwk1cJhi.jpg Here are the contents where you can clearly see the y cable. http://i.pbase.com/g2/82/88482/3/65646505.i5hA77KS.jpg Pretty nice huh, so for the same price you now get the full compatibilty (as confirmed by members on here) and a built-in Y-cable. I will be installing this sometime between now and this weekend to confirm everything works but it is looking good. BTW, if you want to know where I got mine and possibly get in on a group buy ($119) head over to my other thread . Hope this helps! Oh yeah, and if anyone needs a y-cable, I have one on the way I'll sell for $15+ shipping. |
Well I am impatient so I installed it tonight. Works perfectly, XM is perfect no bleed, ipod controls seem to work although I didn't have much time to play with it. Aux in from the MG-25 works great. Overall everything is great. I don't know how hard it would be with the standard Y-cable but even removing the side panel, it was still a little difficult to manuveur the new connector into place.
Overall I am VERY please and glad to be rid of the cassette adapter. |
If this was out a few months earlier, I would have used it in my install. Oh well.
Thanks for the update! BTW, do you hear any whining noises when the Medigate is powering up? |
Whining through the speakers or directly from the HD? I don't remember hearing any through the speakers but I didn't have much time with it before I had to come in. It will get a more thorough listening tomorrow.
Whining through the speakers. Set the USA Spec to aux mode, set the head unit volume to about 16-18, and power up the Mediagate.
Use it for a while and give us a review on it. :wish: |
Ok, I will check that out today. I didn't notice anything on the way to work today, everything seemed clean.
However I did notice that if in AUX mode and watching the MG25 and I shut the car off there is a slight thump. I have a feeling it is because the USASpec is loosing the audio feed (from MG25) just a hair before it actually shuts off itself. I haven't checked to see if this happens when listening to the iPod. I will check things more thoroughly today. I also haven't finalized the mounting (my center console is still apart) I wanted to hide the USASpec all the way in front of the center console (basically under the heater switches) but didn't realize the front cupholder sits there when the console is slid forward. I need to figure something else out tonight. |
I just checled it out for you and I get no audio whine at all when the MG25 starts up (other than directly from the HD). Maybe try jiggling the audio cables a little? Sometimes that headphone connection can be a little flakey.
I also confirmed I get no thump when playing the ipod and it shuts off so it is just the timing between the apec and the MG25 shutting off. |
Thanks for the update! BTW, do you hear any whining noises when the Medigate is powering up? Is there a source selector in the USA Spec? I just ordered the pie x-3, should I return that and use this instead? Thanks again. sunny |
So this is the work all solution for ipod/aux on the TL (with or without Navi)???
This will retain XM while adding in ipod/aux (or both?!) to the car? Can I control the ipod and not have to deal with the playlist modes like the Acura solution? |
Yes to both of you. This is by far the best ipod and single aux in solution for our cars right now.
The only reason I would go with the PIE x3 is if you need 3 inputs or don't have an ipod. If you plan on using an ipod and only need 1 more aux in then this is the perfect product for you. Yes with this unit alone (the HON2y, the previous HON2 required a seperate y cable) you will retain XM and put ipod and one other aux audio source into your head unit. The USA Spec has 2 mode, playlist (which is pretty pointless in my opinion) which allows you to create 5 playlists on the ipod and select them like discs (with disc 6 being the play all option) and direct mode (what most people use) which allows you control from the ipod itself while still getting track up and down from the steering wheel. |
Oh and the source selector on the ipod(at least in direct mode, that is all I have used) is disc 5 vs disc 6 with disc 5 being the ipod and disc 6 being the aux in.
What I don't like about the PIE X3 is the amount of pieces: 1 huge brain and 1 mid sized selector switch box. The PIE X3 also requires a 12V power tap. This makes the install a little cumbersome, but still very doable. The USA Spec is a simple one piece plug and play. |
:agree: or you don't like the idea of having your iPod charging all the time (or charging when it doesn't really need to be charged).
:keke:
I charge my iPod ONLY after the battery dies. I've done this with a majority of my electrical goodies. I guess I am just anal. :tongue: |
Where can one purchase the USASpec PA11-HON2Y?
:keke:
I charge my iPod ONLY after the battery dies. I've done this with a majority of my electrical goodies. I guess I am just anal. :tongue: http://www.batteryuniversity.com/parttwo-34.htm
Originally Posted by http://www.kenrockwell.com/tech/batteries.htm
Care and Use: Completely different from Ni-Cd and Ni-MH, lithiums prefer to be charged early and often. They don't like to be run all the way down. You will get only a few hundred cycles if you run them all the way down each time, and thousands if you charge them up while still mostly full. Lithium Ion's life tends to be measured by how much total energy comes in and out of the battery and not by cycles. Actually you can get more total energy from the battery by only partly using the battery's capacity. Thus I always charge every Lithium Ion battery every night when I've used it the day before, completely unlike the other technology cells. I've gotten great service out of every one I own; I charge my cell phone daily and I've been using it for years.
I googled it and couldn't find it anywhere. What was the shop you got it from?
btw brian, do you have navi? |
Hate to break it to you, but a full/deep discharge of Lithium-ion batteries is exactly what is advised against as it can cause premature battery failure. These batteries much prefer to be topped off frequently and never fully discharged.
They state this: Use iPod Regularly For proper maintenance of a lithium-based battery, it’s important to keep the electrons in it moving occasionally. Be sure to go through at least one charge cycle per month. If you use your iPod infrequently (gasp), you might want to add a reminder to your calendar program. From Wikipedia: A unique drawback of the Li-ion battery is that its life span is dependent upon aging from time of manufacturing (shelf life) regardless of whether it was charged, and not just on the number of charge/discharge cycles. This drawback is not widely publicized. Back on subject, it seems like this device is very new. Its not yet listed on enfigcarstero, logjamelectronics, nor the USA Spec website! :ugh: |
cTLgo, brian posted this thread: Possible SF Bay Area group buy on New version of USA Spec?
:keke:
I charge my iPod ONLY after the battery dies. I've done this with a majority of my electrical goodies. I guess I am just anal. :tongue: However, it is still a good idea to disconnect your Ipod or other device before turning your car on or off. Auto electrical systems can do some funny -- or not so funny, as the case may be -- things at that stage. |
I think I am going to go to circuit city and see if they can order me this if they dont sell it. good info, thanks for sharing it.
oh another question, How well does this work with the navtodvd and the rear camera? are there any problems that you experienced? |
So, anybody using this without issues in a 2005 TL? 2004?
Originally Posted by VelfarreClubber
Circuit City and Als & Eds Autosound is the biggest retailor that i've seen carry the usa-spec products
So what about when you turn off the car would it stop playing on the ipod and eventually shut off? When you turn the car off the ipod stops playing and will shutoff and stop charging 1 hour later. |
oh another question, How well does this work with the navtodvd and the rear camera? are there any problems that you experienced? There isn't really any interface between this and doms nav2go or reverse camera. A media device (like the MG25) connects to this for audio and dom's nav2go for video. The ONLY slight issueI have noticed is that when I am watching the MG25 and listening to the audio via the AUX in of the USASpec, if I shut the car off, there is a slight pop. As I mentioned before, I believe this is because the MG25 is losing power at the same time as the USASpec. However it isn't really loud and I'm not at all concerned about it. |
FYI ... USASpec is providing upgrades for existing PA11-HON2 -> PA11-HON2Y. They took about a week to respond to my email, but gave me a # to call and they'll email you a RA form.
Just fill that out and ship your unit out, they'll do the update and ship it back. info@usaspec.com :thumbsup: |
Just fill that out and ship your unit out, they'll do the update and ship it back. info@usaspec.com :thumbsup: Thanks |
Thanks for the update. Just so that everyone is clear, this works fine if you already purchased the PA11-HON2, but it should be know that there is the added difference between the PA11-HON2 and HON2Y of the built-in y cable. So if you are going to buy now, either order through my dealer or wait for it to become available, don't go the HON2 route.
Thanks |
Mine is under the center console next to the parking brake cables. I knew I wanted it completely hidden and wouldn't need easy access to it again so I put it under there while I had the console out.
How is the iPod activitated. Currently I switch between CD, Radio and XM. What would be the process of switching between XM and iPod?
You hit the tape/disc button until it goes to Disc 5, which is input from the ipod. Disc 6 is input from the aux inputs.
Originally Posted by vadao
Does that mean I can never have my CD changer full with all 6 CD's. Would I only be able to use 4 CDS?
Hey man, glad I finally found this thread!
I've been using a HON2 in my 06 TSX w/ navi for months now w/ a y-cable, I'm defintly going to ask them if they will upgrade me. 1 big question: When powering the car on, and it is already in CD-C mode from the last time you were using it, do you have any bleedover from XM? Whatever station I last had on XM2 bleeds over until I switch modes, but switching back clears the problem. Does the new one solve this as well??? This would be my dream for it. Thanks! |
Freakin' sweet then. I sent them an email, here's to hoping they'll provide me an upgraded one!
PA11-HON2y is available this website
I searched both crutchfield and CC websites, but found only the PA11-HON2... Googled PA11-HON2Y and found it on discount car stereo.com The PA11-HON2Y " availability" 9/5/06.-- which means they will have them in stock by early next week.
I wonder what is the difference between the PA11-HON2Y and the CAS-HON2Y + PA11-HON2? |
