Paired phone simply vanished!
After a couple months of problem-free operation between my TL and my v710, I went to make a phone call yesterday only to have the TL tell me, "No phone found, returning to menu." I played with it a bit, turning off and on the bluetooth transmitter on the phone and such, but to no avail. The bottom line was that my TL simply "forgot" my phone pairing information. My phone still had the TL listed, but not vice versa.
There simply was no warning. I had even used the HFL to both make and receive calls earlier in the day, and nothing special had happened since (like the battery dying or anything like that). I didn't even use the HFL or Voice Command between the last time I'd ended a call and when I found it not working, so I couldn't have "accidentally" deleted the pairing information through the HFL or anything.
At any rate, I ended up having to pair the phone again, then everything worked fine (so far). Anyone else have this problem? Is there something I need to do to prevent it?
mlody
12-04-2019 02:11 PM
ExcelerateRep
10-14-2015 08:20 AM
rboller
09-23-2015 02:49 PM
