non nav to nav mod only $1200 budget
can anyone help me how can i do it, already spoke to martin, he is very helpfull but the price still to high for my budget, it would come out to around $1750 (installed). my budget is very limited and $1200 is the max i can afford since i just bought the vehicle a few days ago. can anyone help me with this. acura tl 04
sell your non-navi.. buy a TL with navi..
Otherwise if your budget is tight you're going to have to do the work yourself (fab, harnesses, install) & score the necessary equipment 2nd hand (fleabay, scrap yard, etc..).
How about an aftermarket solution?
http://www.sonicelectronix.com/cat_i...avigation.html
After reading the posts from the guys trying to do this with the factory units, it just seems too hard. If you can come to grips with the double DIN faceplate, you will get the nav. plus bluetooth/HFL and more features for your budget.
Do it yourself and look for parts at junkyards.. thats how I did it.. I even made a DIY.. search for it .. I have seen people do it even cheaper because they made their own wire harness.. I think the cheapest was around 700.00.. if you buy the wire harness from Martin then that is already 500.00 just for the harness.. You NEED to be patient and find some deals for parts.. took me about 4 months to get everything I think..
does anyone have diagrams on how to make the harness? I have an 04 and want to put the navi form an 07. or if anyone have the navi wire diagram for the 04 and 07, i think i can figure out how to make a harness. my dont have $400 to buy the harness.
thanks in advance to anyone that could help me out.
digikey + service manual
I would suggest the aftermarket route as well.. Get your bezels, purchase a double din.. maybe a used d3 for around 300-400 bucks (best damn DD i've ever use btw...) and a shop to install which usually runs for around 200.. I did mine for under 900 bucks..
Build ur own harness and self install.
I have to say the after market seems like the smarter way to go. The OEM is nice but very limited compared to the may applications the after market way allows. I like the idea of just installing a touch screen in the location the Navi OEM screen goes that can plug in to a device like a netbook and have some way to hook in to the cars systems and moving non navi display lower like mentioned possible on moving non navi display lower in other posts. If I had time and motivation I would/could figure it out. Other wise I will or can wait till some one else does it and I can copy or do it a little differently on my car.
Federation Squirtle Squad
...yeah just get an aftermarket nav like pioneer or so, find one in the ballpark of about 600 to 900 and then use the rest on install money if you are not doing yourself
Mistuh DRiiVA
LUV MY 2007 CBP TLS
Received 2,329 Likes
1) Get a Navi TL
2) Aftermarket (carPC)
3) PATIENTLY find everything on eBay or a junkyard and do it all yourself.
You'll need the wiring harnesses, navi computer, screen etc etc.
InFaMouSLink
10-27-2015 06:52 PM
