New member, new help in 2-12in JL Audio sub-sytem in trunk
Coolest A-zine Member
Hmm.
So if I deciphered that correctly you would like to hook up your subs to the factory setup (yours has navigation)
If that's your question...
Then yes! You can either purchase a LOC (line-out convertor) or just purchase this ( http://www.sonicelectronix.com/item_...SL-09ZISL.html) and take the RCA's into your amp.
Here's what you need to do:
1. Go to the trunk & Pull the top trunk linder down and it will reveal the hole for the sub. Big round hole right in the middle of the rear deck!
2. Reach up in there and find the plug that connects the sub wires to the sub
3. Cut that and splice the wires into the LOC or the item I showed you
4. Take the RCA's into the amp
5. Set crossovers/slope & Set gain CORRECTLY
6. Done.
I accept Paypal.
6. Done.
I accept Paypal.
It's been done a million times before. Try a search, you will find every imaginable combo of subs/amps in the TL from a basic amp and sub to a $10,000 setup.
The 12W6s are one of the best if not THE best I've ever run.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
justin.w13.walker
09-22-2015 02:21 PM
