Need Radio code!! Help!
6th Gear
So I look my battery out of my 05 TL and now its asking for a radio code for my radio to work? My car is from California I live in Nebraska so the whole dealership thing won't help. How else do I get the code? Thanks.
Registered but harmless
Received 1,106 Likes
The Navi and audio passwords were on a plastic business card that came with the car's paperwork. Check the leatherette manual holder's slots for it. Also check the spare tire compartment tray for the card and through the paperwork you received when buying the car.
If you're unable to locate the card, check the owner's manual to see if the passwords were written into the spaces for the passwords.
Otherwise, techs sometimes put the passwords on a sticker in the glovebox area or on top of the underhood fuse box.
Otherwise, you'll need to get the radio's serial number to give to the dealer along with the VIN so it can pull up the radio code; this can be done by phone or in a dealership, IIRC.
Welcome to AZ.
Welcome to AZ.
Dylan Tvrdy (06-20-2012)
turn the headunit off and while holding 1 and 6 turn it on. This will give you 2 sets of numbers/letters with only the numbers being the radio serial number.
Go here: https://radio-navicode.acura.com/
I bought my car used and was still able to obtain my code this way.
I just purchased a used 2008 rdx, it didn't come with the code in the glove box.
I can't get the code from
serial number is 30901065
Radio and navi codes are "underhood fuse box"
Welcome to AZ.
Welcome to AZ.
Jamus22
06-11-2023 10:08 AM
dirleton
09-28-2015 04:48 PM
