Need help,, upper display wont display info
So long time viewer and first time poster,,
I have a 2005 tl W/ navi (65000km) and the upper display above the navi screen wont display any information but at night you are able to tell that the back light is on, this happened right after i brought it home from bestbuy after having a iPod cable installed.
I really need this fixed as it is winter and i cant tell what the climate control is even at, the onlyy way to get heat is through the front window defroster.
Every thing else works...
Let me know thanks
Let me know thanks
They may have forgot to plug it back in after they removed it. The dsplay/vents pop straight out toward you. Search on how to remove it if you are uncomfortable but be careful if you pry the sides off to make sure you don't mark the dash. Once out, check and see if all plugs are connected....I bet one is not.
MrHeeltoe
20
02-23-2023 01:54 PM
ITSJESTER
17
12-06-2018 02:29 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
