Need Help Adding An Amp!
Mine is tied into the big black wire going from the driver's side kick panel fuse box to the steering wheel but many simply tap into the fuse box itself. Do a search on remote turn on fuse for details.
Go to the fuse box with a tester and switch the key on and off until you find one that turns off and on. I take out the fuse and insert the spliced wire into the fuse location and push the fuse in on top of it.
InFaMouSLink
10-30-2015 09:43 AM
4drviper
09-23-2015 09:00 PM
