Navigation and voice command through all speakers
Does anybody know how to make my navigation voice and voice command play through all or some of the speakers. I've been googling and searching azine and not having any luck.
I have an aftermarket processor and my HFL and navi come out over all speakers. It even has a nice center image and bass you never knew was there. The HFL actually has a subsonic rumble that I don't like. With my setup it's as easy as using the mixer to tell it which inputs go to which outputs.
If you're all stock you would probably have to go with an aftermarket 5 channel amp. Take the center channel and front left and right outputs and run them to a 4 channel line driver or LOC depending on how you choose to do it but use the inputs of both the center and fronts into the amp. From there it will distribute to all channels.
It's a lot of work just to have the sound come out over all speakers. It's something I would do if I were already installing an aftermarket system but definitely not just to get the sound over all speakers.
TLguy42
09-26-2015 11:27 AM
