Navigation problem
Navigation problem
Hello, I purchased an 05 tl with nav in june 2010. As of yesterday my navigation screen just stays black. When I start the car it says downloading software and to not turn the car off. When that finishes, the screen goes black and can't be used in touch screen or other controls. My radio itself does still work. Does anyone know what the problem could be? I definately can't afford a new unit, sending it to alpine is an option. I just really would ole to know what the problem is.
'06 WDP TL 6MT
I'd try a known-good DVD in the navi drive in the trunk and see what happens. Also, you can try letting it reload from the disc:
press Map/Guide, Menu, and Cancel buttons for 5 seconds
press Version (there is a slight delay before this is pressable)
press Disc Load
press Disc Load
you will need to send the dvd drive unit in the trunk to alpine.
Alpine Service number: 1-800-421-2284
DVD Drive Ref #: BN417AA
Acura replacement part# ($2745): 39546SEPA51
Address:
Alpine Electronics
2012 Abalone Ave., Unit D
Torrance, CA 90501
Provide:
Check for $158
Name
Return Address
Description of the problem
It'll take 5-7 business days to return it.
Address:
Alpine Electronics
Torrance, CA 90501
Provide:
Check for $158
Name
Return Address
I have the same issue Lefty...Ive tried about 5 different nav cds and even took the player out of the trunk and reinserted hoping it was just a loose connection..Nope.
Justnspace laid it all out for you if you choose to go that way...
Instead of doing the repair on the dvd player (which will likely just fail again) i am choosing to take a different route by using my iphone's navigation and having it send the info off my iphone to the nav screen! You might want to consider doing the same...
2005 AM at/navi
BoricuaTL
04-08-2016 01:08 PM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
Gianni Formica
09-07-2015 08:28 PM
travr6
09-06-2015 02:11 PM
