Navigation keeps asking for code
Okay so I bought the car from the dealership 4 days ago and the navigation system asked for the 4 digit code. I enter the code and it goes through the whole reboot system and the navigation map shows up, but when I turn the car back on it ask for the code again. Can anyone help me out?
Registered but harmless
Received 1,149 Likes
That means that the battery power is disconnecting for some reason.
Tighten and clean the battery clamps as necessary. Check the battery cables for corrosion as well(including under the sheathing); replace if necessary. Check cable tightness at the ground and starter ends.
Then check battery voltage/condition- a dying battery can cause the Navi and/or radio to ask for a code.
Report back if that doesn't resolve the problem or if the car has other electrical issues.
gatrhumpy (08-01-2019)
CmMx112
07-30-2019 08:44 PM
Jerry_in_WA
09-04-2016 04:39 PM
GuyIncognito
10-09-2015 01:44 PM
jimmyl729
08-27-2006 07:58 PM
