Navigation control unit failure?
#41
I'm Craig
Mine has been booting up normally 10% of the time. 80% of the time it boots after driving for 10 or so minutes. Then the rest of the time it doesn't boot. I called Alpine a few days ago and it takes 2-3 weeks from the time its shipped out to the time you get it back. So I'm just waiting until after I travel for Christmas and such.
Doesn't really make me any less happy with my car. It's Alpine's fault, not Honda/Acura's. Oh well. Worse things could happen.
#42
04' Acura TL Anthracite
Ok, so before I go through all the efforts of removing my control unit, due to this constant rebooting, are we 100% sure its not just a bad disc that keeps it rebooting?
Its for sure the control unit?
#43
I'm Craig
^Seems so. Based on other people's responses, sending it to Apline fixed the issue. Mine has been better lately, boots up normally 1/2 the time. Other times it takes 5-10 minutes of endless booting. Blah...I need to send it in. I swear it has something to do with the cold weather because if I've been driving the car for a while and get our for a bit then get back in, the nav boots up just fine.
#46
#47
Thats another good point. What do you think they'd say if they came back to me and said, it will cost $xxxx amount of money, and that number would be outrageous as expected, and I said I can send it into Alpine for $150 and have it sent back fixed, can you please take it out of there for me?
Think they would?
Think they would?
#49
I'm relieved I took my friend who is an Acura finance mngr's advice and bought the extended warranty because of these issues with the navi. He told me it was the number 1 failure with the newer TL's and very expensive in some cases. Even my scheduled Maintenance was pre-paid for..lol.
#50
I'm Craig
Think they would?
Think they would?
#51
I'm going to give it a try this weekend. Found the easy to remove screws, but there seems to be one small other kind of fastener or bolt in there, towards the back side where the light is, behind the light?
#52
Knowing the dealer, they'd probably charge to just take the unit out. Although it might look and seem intimidating if you've never taken anything apart on your car, it's super easy to remove the trunk lining. Just a matter of a couple of screws. There are many DIYs in the 3G Garage for this. When I first joined Acurazine, I never thought I'd have the guts to take anything apart. And within a year, I was pulling my entire front interior apart (navigation screen included) to replace burnt out light bulbs. It's really kind of fun if you have patience, etc.
I wish my car had the extended warranty. Unfortunately, electrical gremlins like this are bound to happen at some point when there's so much technology in a car.
#54
Mine just went out on me this weekend. Started as a blurred display, then lost sensitivity, then failed to boot completely. Also lost the LED radio display at that point. Already pulled the unit, its very easy once you get the trunk liner peeled back. 7 or 8 screws holding the harness in and about 5 electical clips to unplug. Do we need to call Alpine first, or can we just send it in following the listed instructions and the payment?
#55
got mines back from alpine with the same problems as the rest of you, but it came back still broken!! now i gotta resend it according to alpine support, free under warranty. hopefully they fix it next time around.
#56
I'm Craig
I'd call Alpine first. They'll tell you the address and instructions.
#57
Does anybody know if the rest of the system will still function safely once the Control unit in the trunk has been removed.
For example while the unit is at alpine, is it ok to just leave the connectors free hanging in the trunk and continue to use the radio/bluetooth?
#58
I'm Craig
As for using to other stuff, I'm sure it'll be fine to do. I wish it didn't take two weeks though...I've yet to send mine in.
#59
2005 AM at/navi
did you get your unit out already? i have a thread of a diy video for this. you mention the light but you dont have to remove anything that far up. search for revoming navi control unit. i think that was the title i used. mine is finally going out tommorrow morning to alpine hope they fix it.
#60
2005 AM at/navi
i juat got mine from alpine today and it works perfectly. for 158 dollars it is a bargain. definately worth it plus a money back warranty of 90 days.
#62
Do you have a link to your video?
#63
Finally found jr27's link to his YouTube video!!
http://www.youtube.com/watch?v=BZIlb...layer_embedded
#64
I have the same problem -navi reboots over and over again. Similar to cjTL, my navi also boots up fine >50 degrees.
However, when the engine is off and when I have the key turned to I - the navi works perfect. When I turn to key to II, with engine on or off, the rebooting problems occur.
Could it be a defective unit? Navi works perfect when key is on I. It seems as if the navi is not getting enough power.
#65
2005 SSM/Ebony/5AT/NAV
Mine finally failed on my 05 TL about a week ago. Sent it in on Weds. They still said price was only $150. 7-10 days turn around.
Only problem is that I now have no stereo until it gets back...DOH!!!
#66
Rather than start a new thread, I will discuss my issues here.
I never had an issue with my nav unit. Purchased the latest DVD upgrade and all was fine for several weeks. When the problem started, the nav initially was giving me incorrect roads and city areas. Then all of a sudden, the screen would not display at start up. It stays blank up to 1/2 hour, or, it blanks out while driving.
I took several photos of the screen while driving and a message displayed by the unit. Took it to the dealer and received their customary response "we couldn't duplicate the problem." So I said I have photos of the screen and the tech says it is the battery. I replied that battery is a year old and when the old battery died it didn't exhibit this behavior. So they did a battery drain test and that didn't reveal anything. Two days later, it blanks out and I am down the street from the dealer so I drive it in. Tech examines it and says I need to make an appointment to bring it in.
I have an extended warranty and they are doing everything in their power to not give me another unit. I also have a Nav-to-go that is only hooked up to the ground screw and the reverse light. It was never connected with the pnp harness or connected to any power.
Sorry for the rant, but I'm getting a little tired of driving around with a black screen.
Should I remove the unit completely before I take it in?
#67
So I digress... They said the exact same thing. Bad battery. Mine ended up being bad and was replaced under warranty. They told me to check things out in a few days. The Navi started lagging again. My dealer thou has no problem testing out everything and doing anything to make me happy including sending off DVD Rom reader or the screen itself to swap. That said, I have purchased 10 cars from them in the last 12yr's as well as sent my mom there and she's since purchased 5 cars since 2001. I also have sent 30 others to buy hondas/Acuras from this dealer so they may be kissing my ass a bit. Anyway Like ive said I'll be sure to post exactly what they find wrong if anything. I do have the 2008 disc I bought the car with last June and it was also brought to many peoples attention that the 2010 disc cleared up a lot of the lagging. Your issues a disc wont solve but it could def be something faulty in the screen or DVD ROM drive which many have had replaced/repaired and it did the trick. Just keep pushing bro even if you have to call Acura Customer Service.
#68
2005 Acura TL Navi issues
First off, thanks to everyone for their posts and info. I just recently been having the same problems everyone else here seems to have. Occasional rebooting/reacquiring then when it is working becomes very inaccurate, by 10s of miles. Accessing the Diagnostic mode showed complete satellite lock and that all seemed OK. I just called United Radio Services (URS)
5717 Enterprise Parkway
E. Syracuse, NY 13057
Phone: 1-800-634-8606 or 1-315-446-8700 Fax: 1-315-446-8505
they quoted me $350 flat rate to repair it, that includes shipping and insurance both ways. now I guess I have to decide weather to go that route or rig up some kind of carpc.
#69
Registered but harmless
Received 1,102 Likes
FYI, Alpine in Torrance, CA does Navi DVD repairs for @$160-- the Alpine address and phone info is in just about every 3G TL "Navi dead/dying" thread except this one.
G/L regardless.
#71
Location: On the banks of a filthy river in east TX ruled by crooked cops, brazen women and pansexual cowboys.
"Please Inert Disk"
So like pretty much everyone else here I started having issues with my navigation system in my 2006 TL earlier this year. At first it would display the error message "please insert disk" for maybe a day or so at a time and then work normally after, but as of about two weeks ago, the unit seemed stuck on the error all the time.
After reading up on Acurazine I found this thread, called into Alpine and verified the charge to repair (flat $158), and went ahead and shipped it off to their address in CA.
Looking forward to getting it back from Alpine and being able to use my Nav system again as I can't believe how much I relied on it.
FYI here's the contact info I used for Alpine:
1-800-421-2284
2012 Abalony Avenue - Unit D
Torrance CA 90501
Torrance CA 90501
#73
#74
I'm Craig
Ouch. Glad mine failed last year then. Better not fail again anytime soon.
Not only the cost factor but the whole thing was a fiasco. Alpine's customer support is a joke. I sent it and it took three weeks for the damn thing to finally receive the hour of work it needed.
#75
Mine failed while under warranty last summer. My car only has 51k miles..lol. I found a good cpo ate the time. my navi still lags bad. TBhey dint give me a new dvd. Mine has 08 white disc Acura told me that disc lagged in the 1st place. Any scratches only makes it worse so they're trying to swap it out.
#76
This seriously is the worst news ever. I'm going to be calling later today to confirm, and I'm hoping that maybe this isn't the case...but I have a bad feeling. I can't understand the justification of going from $158 to $358 for the same exact service. Its absolute garbage that Acura knows how touchy these units are and how they're bound to fail, and its even worse that Alpine is upping the price on us. Right now my unit is working minus the voice commands,when she goes to talk to me it sounds like popcorn popping. I might just buying a Garmin and call it a day. By the time I spend the $358 & $99 for the newest disc I could save $400 and just eat it.
#77
It's official its $358 for sure, what a joke. The support person from Alpine sounded like he could care less about anything. When asked about why the price doubled he had no response whatsoever. For that amount of cashola, I'm muting the voice command and just forgetting about it. I want to trade this thing in asap and get out before additional issues come up.
#78
Former Whyner
FML this just started happening to me. 358...naw im good. I have noticed that this is in relation to a "time period" if car is off. It never fails that starting the car in the morning (after sitting all night) I get the reboot process for about 5-15 mins, however a startup or initialization of the NAV (starting the car within 60 mins) I receive no errors at all and I get the "ok" button.
If this was to happen on EVERY startup then that would make sense but there is something more if this occurs after 1-2 hours after you have shut off the car..
#79
ok my problem is alil dif than everyone elses. but this seems like the best thread that iv found so far to ask this question.
before i ask i know a few ppl are goin to say ( thats ur problem there) but please read before wrightin it off so fast.
i removed the factory head unit and replaced it with an apline head unit. its a single din head unit. the mounting holes lined up perfect with the oem head unit holes and the face sits perfectly flush with the nav.
my problem is that when i turn the car on the dissclaimer screen comes up, the ok button comes up, but when i touch the ok button nothing happens. its like the screen is unresponsive, a few seconds later the screen goes black, just as if you had never touched it at all.
i know that oem head unit is tied into the nav and all that jazz. but shouldnt the nav touch screen work still?
thanks to who ever could help.
#80
I'm Craig
^I wouldn't expect it to work perfectly. I never press the OK button though unless I'm actually using it to navigate somewhere. I usually press the "Audio" hard button after the OK screen pops up. Wonder if that works in your case or not.
