navi lost??
navi lost??
my navigation seems to not be able to correctly track where i actually am. it shows me driving and making turns but i am usually off road or within the vicinity i actually am in but not on the actual road.......sometimes it will jump to the correct position but often it starts in the wrong place....
any help?
any help?
Go to setup...vehicle settings, and recalibrate the gps to your current position.
Don't drive so slow.
Registered but harmless
Received 1,149 Likes
Originally Posted by Jason1000RR
Where is "Vehicle Settings?" Is that something the 05 NAV is doesn't have?
If that adjustment does not work for OP, then something else is wrong-- maybe check for metallic window tint on the car, as the tint supposedly blocks the GPS signals.
G/L.
Originally Posted by Will Y.
The posters are referring to the Nav System Setup, which is accessed through the "Setup/info" button to the left of the Nav joystick. Adjustment of the vehicle location is on screen 4, per the Nav manual for '05: https://techinfo.honda.com/rjanisis/...505NMAINID.pdf
G/L.
G/L.
Here is what I have going on. The GPS takes minutes to obtain a good signal (GPS text turns white to green), is this normal? So while it doesn't have a signal my location is totally crazy off plus the North-pointing is wrong too. I don't have metallic tint either. I have normal black tint and I don't think it's made of metal!
Originally Posted by bent09
Did you resently upgrade your disk?
I did and now it always gets lost. It is horribly frustrating. It seem sI have to relocate my position once a week!
Not really recent but I do have the newest disc...
Sorry to sound to ignorant but is there a way to "auto-calibrate" the GPS? I'm failing to see the point of me choosing my own location on a map to calibrate it...
My Nav automatically locates the car within a few seconds of pressing "OK" on the warning screen, except where I am beneath more than 2 levels of garage/other cars or in a tunnel where the GPS signals cannot penetrate. Once the car is outdoors, it is located in seconds.
Also, if you touch the arrow within the circle showing your location on the screen, it will switch the orientation of the map, between "North on top" and your car's forward direction on top.
If the manual and this post don't help, drop by the dealership and have it either calibrate or fix whatever is wrong. G/L!
Being an Acha Bacha in
I have the same problem in mine, but it only happens sporadically, it will show me driving on an expressway when I have clearly exited or it will show me in the gray zone and not on a street but moving parallel to the street that i'm really on.
It usually fixes itself after I look away and just start cussing for 5 mts. and then I look back at the screen and its back on track.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
