Navi Display & Radio
Old 11-03-2016 | 12:03 PM
Reggie Gibbs's Avatar
I have an '06 TL Base Navi AT and my navi is blacked out, radio works but no display of radio info only wrong time. Yes this happened after a battery change. I have tried resetting the fuses# 5, 7, and 32 with no luck. I used to get a display once in a while and then it would just go black. Now I dont have any display at all. The display itself has a backlight but thats it. My DVD player only accepts a DVD. any help with this would be greatly appreciated. I have removed the HFL device because it went bad and was draining my battery. I also have the DVD player out the car currently. I can put both of these devices back in the car at any time if needed to do any tests required. Thanks in advance for any and all help!
-Reggie
Old 05-10-2017 | 10:49 AM
f1r3w0rK5's Avatar
Sounds like we are having a similar issue. I had even disconnected my DVD unit from the trunk for a while, and just recently reconnected everything. I haven't checked the fuses yet because my navi went through like phases. 1.) It would work intermittently, and when it would I would have to enter in the code. 2.) It would go through the continuously rebooting phase with the "navigation system" 3.) Then I would get the black screen with the blinking white lines. Now I get nothing at all!!
Old 07-15-2017 | 03:49 PM
bigracer5's Avatar
6th Gear
-Reggie
I have the same problem, do you have a solution ? Do you know how todo set up the clock without the GPS ?
Thanks!!
Old 07-15-2017 | 04:46 PM
AZAEEC's Avatar
BANNED
swap the nav brain , you can get one cheap on ebay
Aaphree
68
01-07-2024 07:56 PM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
11-07-2016 04:31 PM
YungMoola15
11-03-2016 10:42 AM
joevasco
06-01-2016 09:59 AM
Aaphree
02-25-2016 11:30 PM
