Nav Hack Ok button question
After uploading my new AD navi.exe file utilizing the dumpnavi utility I receive the following message within command prompt....
Updating navi.exe ...
The size of the updated file must be less-then or equal to the size of the old file. This feature might be introduced in a newer version. Updated file <COMPRESSED>: 3028352 bytes Old file <COMPRESSED> 3028315 bytes
When I load the new files into the navigation the ok button is still present. What did I do wrong?
I had the same problem. Open the navi.exe file in notepad, scroll down towards the bottom and look for the french words. It takes a few minutes, but delete some of the french text, save it, and try to use dumpnavi on the navi.exe file. With the frech text out, it should save to a smaller file size and you won't get this error any longer.
I deleted a few of the French words and then was able to upload the navi.exe file. However after loading the CD to the navi system and then putting back in the factory navi CD all that will load is the navi start-up picture. The picture loads as usually and once it would go the the Ok screen it just blinks and goes back to the picture. It will not load the map. Would it matter that my TL is an 06?
BoricuaTL
04-08-2016 01:08 PM
