Mini Dreambox BUILD = Decisions Decisions. 2ohm or 4ohm - Dual or Single Coil
#42
#43
takin care of Business in
Received 4,732 Likes
hey dude....can you please put the dimensions of the wood blocks for the box???
#46
SHAWD 04TL is in
SORRY FOR NO PICS ON THE DREAMBOX, GUYS..... switched banks & forgot to update my server charge credit card..... IT LAPSED. Got it back on though. You shoud be able to see them now.
#47
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
#52
I'm going to attempt this guys and I don't have that much experience with wood, but it looks pretty straight forward.
for the guys that are asking for dimensions, why not just pick a sub and go with the specs it calls for.
so in order to get the dimensions, you would have to measure your trunk space and figure it all out.
Honestly, It doesn't look all that hard. Just take your time and make sure the measurements are spot on!
Since this will be my first time building a subwoofer enclosure, it'll be a little sloppy but expected. Then you can go back and make adjustments if needed, or make a whole new box.
MDF is fairly cheap, so if I screw up I can always get more.
#53
You guys can't use Roger's box design for a different sub, it won't work.
All I can say is I built my own and if I can do it, anyone can.
#54
Thanks IHC for backing me up.
As for the design, its awesome and when I was reading Jason's thread I KNEW I HAD TO HAVE THIS.
Also guys the internet is your friend, Don't be afraid to research how air moves and how to produce the best sound out of the box.
I don't have any experience at all with sound or wood working but I am confident that with enough patience and the correct measurements it'll come out just like Roger's box.
#56
SHAWD 04TL is in
glad to see more people trying this. Met up with some TLers in Reno this past weekend & they were pretty impressed with the small scale of this thing. Sounds way bigger than it is.
#59
Ive tried so many boxes and couldn't get any of them to sound right. Im not looking for super loud but more accurate, fast and deep without losing breath if you know what i mean.
I have a Boston G5 12" ... and its a great sounding Subwoofer but in the TL its so hard to make it sound good.
If anybody could help me out and give me the cuts or just some info id be so grateful
thank you
thank you
#60
thank you
thank you
#61
Mine is front firing trough the arm rest opening in a sealed box build to specs. From the face of the Subwoofer everything back is sealed off completely. or at least as much as i could have sealed it off. And then there is that space from the width of the subwoofer box to the opening of the arm rest, which is another champer and then into the cabin. Looking at this design it doesn't vary much from mine.
#62
I believe i sent you pictures of my install a while back which pretty much looks similar to this design but not completely.
Bandpass has to be exact. Both chambers have to have the correct volume and the port has to be tuned with the right length and width. The box has to be built to your exact subwoofer, there's no such thing as a prefabbed bandpass.
#63
http://img195.imageshack.us/f/img2882c.jpg/
there you can see exactly how it is ...
here is the rest http://img195.imageshack.us/gal.php?g=img2882c.jpg
#64
That makes sense. As CSW put it, you're going to get sort of a weird bandpass response. It will never sound just right with that setup. You have to have a front and rear chamber sized just for bandpass and airtight made just for your sub along with the proper port dimensions.
What you did is the last thing I did before I went to a bandpass. I had to run a ton of power to get any low end and on some music it sounded tight but on most stuff it was not very accurate. With the true bandpass, I cut my gains by over half and it's soooo much louder and more accurate now.
#65
so please help me out designing a box for the G5 i should require the same cubic space as the W6
#66
I guess i do have a badpass design but not a controlled one. It does sound exactly the way you describe it. for example country sound very hollow. rolling down windows seems to help a lot.
Honestly, the best way to design one is to come up with the volumes and port requirements from the manufacturer and design the dimensions to fit in the TL. Designing one of these boxes is way beyond mine and most peoples' knowledge. I copied CSWBiggs design and blueprint which was based off of JL's blueprints. Some people have the programs to design them but it's complicated.
The specs for my W6s won't work with yours. I believe a lot of it has to do with the TS parameters of the sub. Or in other words, one 12" sub can vary greatly in it's requirements compared to another 12" sub.
With this design if I had it to do over again I would go with only one 12". One 12 in this enclosure would be louder than 2 of them in a sealed enclosure. I could've saved a ton of trunk space.
When I first built the box I was thinking there was no way it could work. The sealed part of the box is 1.29 cubic feet. It's as small as you can possibly fit 2 12s in. They're nearly butted up against each other, the box it only large enough to fit the diameter of the subs and clear the magnets. These setups are a whole new world to someone like me who lacks experience.
#67
I guess for me to get it right would be a miracle
Im just tired of experiencing as i have spent so much time trying to get it right. I mean its tolerable, its not bad but not really up to my expectations
maybe i should get rid of my two G5s and get one W6 and copy you![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
im even waiting for you to find out about that thermostat for the lack of low end power and sluggishness.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
if i could fix that problem... a supercharger would not wait long ...
#69
Keep us updated on the build.. We may have to do a TX meet so I can hear the mini dreambox.
#71
No problem with that.. keep us updated.
#72
SHAWD 04TL is in
![what](https://acurazine.com/forums/images/smilies/what.gif)
BTW, your specs look good!, can't wait to see the finished product.
InFaMouSLink
10-30-2015 09:43 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
AcuraKidd
09-25-2015 11:18 PM
