Make your Own DVD Audio! What?????
8 Foot Asian
I have read a couple of threads regarding how easy it is to make your own DVD-A discs. The only problem I have is the fact that in order to make a DVD-A disk you either need to:
A: Buy a DVD-A disk so that you can burn it (retarded option)
B: Borrow a DVD-A disk from a friend whom probably doesn not exist to anyone including myself.
C: Burn the audio track of a movie which is even lamer than option A.
So in conclusion if we cannot create 5.1 audio disks from the mp3 files that we burn from the net, and since you cannot download 5.1 audio mp3 files from the net, and since you cannot rent DVD-A disks from blockbuster. WHAT THE HELL ARE YOU NERDS BURNING ON THESE DVD RECORDABLE DISKS !
Please help us all out b/c I have a DVD burner in my computer and want to start ripping DVD-A disks right away, I only want to know where you guys are getting the music from!!!!
PLEASE HELP!
PLEASE HELP!
1) Calm the frig down.
2) A normal compact disc can hold about 70 minutes of "cd-quality" audio. a DVD disc can hold about 450 minutes of "cd-quality" audio. If you want "dvd-quality" audio, that takes up more space so you can fit less - about 130 minutes.
When people talk about burning songs on a DVD-A disc around here, they're probably talking about burning "cd-quality" audio onto a DVD.
-Steve
-Steve
Can't copy DVD-A
PLEASE HELP!
PLEASE HELP!
A: DVD-A discs are not DVDs with music on them. A special program (not Toast or EZ-DVD creator, etc) is required to make them. On the cheap, your only real option is the discwelder series products. Beyond that you're into professional-grade software and trust me the cost is also professional-grade.
B: You cannot copy a commercial DVD-A disc. The byte structure of the disc is incompatible with any DVD-R, consumer or professional. For those of us in the industry, this is one of the great things about DVD-A.
Now that that is cleared up, yes, using discwelder software you can put quite a lot of stereo audio on a DVD-A disc and that is pretty cool. Thanks for reading, ric
As a matter of fact. The TL will ONLY read the DVD-R format. all others DVD-RW, DVD+R etc. cannot be read.
How do i know?
I have discwelder. And its FANTASTIC. 90 something songs on each disk. I could go weeks without hearing the same song twice..
How do i know?
VTEC HoooA
One source that is often overlooked are the DVD-Video concert releases. Most of these are recorded in 5.1 and are not available on DVD-A. So you can rip the concert 5.1 sound, then burn it out to a DVD-A format and PRESTO 5.1 surround!
I wish that they would release more DVD-Audio disks soon.....
Where is the Cure (Mixed Up in 5.1 would be simply stunning)??
Where is Depeche Mode??
Where is Orbital??
Where is Moby???
Where is Orbital??
Where is Moby???
DVD+R appears to be a crap shoot; it works for some but not others.
Mike
I make "mixers" as well using the DTS or DD source from the DVD-V "side" of a DVD-A and standard stereo material from CDs. For example, I have a really great Queen mixer with material from the Greatest Video Hits as well as my Night at the Opera and The Game DVD-A's. The sound difference between my DVD-A's and the originals is minimal in the TL, and I only carry $1 DVD-R's instead of the $15 masters in the car.
Mike
YES .. DVD-R disc do work .. I have converted my MP3s to waves (2 channels) ... I can put about 89 songs on 1 DVD-R .... plays just fine in the car and the RANDOM .. works wonderful........
also ripped a concert disc ... used the audio ... from it ..
DISCWELDER is the program I use to make DVD-As for the Acura ...
WayTooManyAcuras
If you have a soundcard that can record 4-6 channels simultaneously, you can create your own surround DVD-As from surround SACDs, DVD-A's, DVD-V's, and old quadraphonic records and tapes from the 1970s (check eBay). Just playback the disc or tapes from the proper player into your PC, clean up or edit the wav files, then make your own 5.1 or 4.0 DVD-A.
AFAIK, you can't rip the surround SACD tracks, but you can record them during playback.
:-jon
:-jon
I do my own work.
Originally Posted by svtmike
...and I only carry $1 DVD-R's instead of the $15 masters in the car.
That's a good idea, Mike. I might have to do that if I can figure all this ish out. lol
8th Gear
I have been using Wavelab for months and burned a lot of DVD-A. The thing is you need some strong software to convert the bitrate and sample rate up. The quality is much better than cd quality. (anyone who has normal hearing WILL hear the clarity) I usually put @24 - 30 songs at teh highest bit-rate and sampling possible.
My $.02
My $.02
17/TLX/Adv/FBP
Team Nighthawk MechE
Originally Posted by csmoore
Which version do you have? Looks like the "silver" version can burn multiple directories, but bronze can only have one. Is bronze adequate for your applications?
Also, only a max of 99 songs will the TL recognize (damn... I sound like yoda there...)
Originally Posted by DarkWraith33
As the TL will recognize only 1 group (directories as u called them), there is no need for multiple groups, so the bronze is OK...
99 songs in a group is the max the DVD-A spec allows (in other words 99 songs is not a TL thing - it's a DVD-A thing), so theoretically you could get 891 very short songs on a disc (99 songs x 9 groups).
Mike
CEO, Team Anthracite
This is true. U2's Go Home is particularly good.
Mike
Mike
I was just reading this post over and from what it sounds, you're saying that you can burn a DVD-Audio using DTS or DD streams? I thought a DVD-Audio wouldn't be able to decode a DTS stream?
The TL can play multiple groups. You hold in the RPT and SCAN buttons simultaneously for a few seconds to switch groups.
Mike
Mike
Originally Posted by Lore
Hi Mike,
Just did it last night with my Peter Gabriel "Play - The Videos" DVD as a matter of fact. I expect that to sound great when I author up the DVD-A tonight.
Mike
I use my computer to decode the DTS stream to 6 mono .wav files.
Mike
Mike
17/TLX/Adv/FBP
Gotcha! Now that makes sense. Thansk
Carl
Let us know what you use for conversions. That's the DVD I'm looking forward to somehow getting on DVD-A.
Carl
Carl
As for software, WinDVD Platinum ($70) has the necessary decoder. Everything else to extract the sound is freeware.
Figure out which chapter in the title set corresponds to each track. Rip the DVD to hard disk, and demux the correct DTS streams (I used vStrip for this). Use azidts, which takes advantage of WinDVD Platinum's DTS decoder, to decode the DTS stream to 6 .WAVs.
You can find tutorials that will teach you how to do this stuff (and much more) on doom9.org and hydrogenaudio.org.
Mike
Team Anth. Audio Engineer
When you convert DVD-V concerts, do you have problems with breaks between songs being at the wrong point? I use Chapter Xtractor after the demux process to break up the songs, but it seems like I spend a lot of time tweaking it to get every song to start and end properly. I know some people just skip the extract step. Any advice?
Originally Posted by bzss7x
Mike,
I've found a few things that work for me when converting:
1) Use SmartRipper and split by chapters on a single angle to get proper splits. If you are extracting streams, use stream processing in SmartRipper to rip to VOBs and then use VobEdit to demux the specific streams.
2) If using VStrip to extract streams, have it split by Cell-ID, then check each chapter to see which VOB/Cell(s) it corresponds to. The nice thing about streams is they generally can just be concatenated together, so if a chapter consists of multiple VOB/Cell IDs, you can just join them up with your favorite file concatenation method.
I've learned a lot more about DVD file structures and authoring than I ever intended thanks to owning this car and my new-found predilection for 5.1 music.
Mike
Thanks for the good advice - I'm sure it will help.
Burn.Now
I have used Burn.Now from Ulead to burn a compilation disk for use in my TL. I use a DVD-R. The player recognizes the disk as a DVD-A but then ejects it. I am assuming it is a CPPM issue. What am I doing wrong and why are others able to record compilation disks on DVD and play them in the TL? Any advice will be most appreciated.
WayTooManyAcuras
I believe you need Wavelab 5 or Disc Welder, Burn.Now only burns DVD-Vs.
WayTooManyAcuras
http://www.ulead.com/bn/features.htm
Burn DVD-Audio Discs
Get 6 hours of great, uncompressed-quality music on a DVD-Audio disc. Play on DVD-Audio players or on DVD players that support the DVD-Audio format. .
I guess you are correct!
H.T.Chien
Dear Alberta:
Can you tell me the player model you use to play the Burn.Now DVD-A disc??
Can you use the software player InterVideo WinDVD 6 to play the Burn.Now DVD-A disc on a PC??
How do you know it's related with CPPM??
Regards,
H.T.
Regards,
H.T.
Originally Posted by htchien
Dear Alberta:
Regards,
H.T.
Regards,
H.T.
H.T.Chien
Originally Posted by happyalberta
I am not sure what the player model is in my Canadian purchased 2004 TL. I can play the disks I have burned with Burn.Now on my computer using Cyberlink Power DVD 6. When I first try to play the disk I get the message "CPPM must be activated before playing CPPM protected content" It is only when I press "cance" and get the message "CPPM not activated" that the disk plays on my computer. I am presuming that the dvd audio player in my car is having the same problem and there is no "cancel" to press. The disk is simply ejected after having been identified as dvd-audio disk. Any ideas?
Thanks for your answers, and best regards,
H.T.
H.T.Chien
I think the car player you use is Acura ELS Premium Sound System and is made by Elliot Scheiner based on the technology from Panasonic ( http://www.surroundpro.com/articles/...icle_200.shtml ). Is this correct??
H.T.
H.T.
H.T.
H.T.
I think one of you guys that have successfully made the transfer of DVD-V's to DVD-A's should start your own little business of selling homemade DVD-A's to unsavy computer illiterate guys like myself
Coming to a city near you
did anybody ever make a How to guide with pictures for discwelder. I think it would help a lot of newbies out. I was going to, but i always get distracted and still havent made one disc yet.
Computer Techie Geek
this thread should be usefull enough on making a DVD-V -> DVD-A
https://acurazine.com/forums/showthread.php?t=110542
Has anyone had any problem with their burned DVD-A discs skipping to the next track before the current track is finished?
This does not happen with every track, but while listening to some tracks the disc suddenly skips to the next track. This seems to happen randomly. Sometimes 5 seconds into the track, sometimes 2 minutes in.
I am using DVD-R media.
