Low audio output
Low audio output
Hey I have a 04 TL and my driver side tweeter and speaker are way lower then the other side. I switched the tweeter thinking it's bad but still driver side is low vs passenger. Anyway of testing this? Or should I get get a new amp?
Did you check to make sure your stereo equalizer was centered? The settings might just be faded on the drivers side....
Press the tune/sound button down until you get to "CNTR" to make sure its not +/- anything
If that doesn't work, I would suspect the amp is the culprit as well
If you didn't check the balance before posting then you get a
if you did, then it's the amp
nuresh
95
08-12-2012 02:17 AM
phenryiv1
03-14-2011 10:35 AM
