Looking for 06TL Camera
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
I have a 06TL/navi. Looked all over the forums in an attempt to get info on where I can get a backup camera (No DVD), general instructions on how to wire/install. Would like to toggle between navi and camera when not in reverse.
Sounds like Wendy's camera is the way to go, but most posts on the subject are quite old.
Suggestions?
Thanks in advance
Suggestions?
Thanks in advance
you will need the following:
Dom's TV NAV 2 GO ( sold in the blackmarket section here in groupbuys)
Backup camera
Misc. Wiring
wire cutters
switch
Diode
This is what you will need to do:
Install Dom's TV NAV2Go
Plug the video output from the camera into the 2nd video input
there will be a wire on dom's for the backup camera toggle, connect this wire and power wire to the camera to the reverse lights.
Install a diode on the wire for the reverse lights so the current does not turn on your reverse lights
Wire a wire from a 12v source to a switch.
From the switch take the wire to the trigger wire combo
This way when the car is put in reverse, the rear lights will power the camera, and cause the video wire to trigger. When you want the camera, flick the switch and it will simulate that the backup lights are on, but the diode will prevent the lights from turning on so the people behind you are not scared.
Backup camera
Misc. Wiring
wire cutters
switch
Diode
sorry about the typo, you will need 2 diodes:
http://img110.imageshack.us/my.php?image=camerana2.jpg
![](http://img110.imageshack.us/img110/3886/camerana2.th.jpg)
Did you buy dom's unit? Dom's unit will provide you with the inputs (RCA plug) so you can have it on the navi screen. PM me and I can help you out with it.
navtool.com
31
11-16-2015 08:30 PM
