Just Upgraded Navi to 4.62 in my 2007
#42
Originally Posted by NDe
I started to use ImgBurn to burn my ISO. This time, you use Google to search ImgBurn. Don't use those Roxio or any of those music burning software. With Imgburn, it takes a total of 3 clicks to burn. Easy, fast and safe. So I stop using Nero. I also switch my XP Pioneer DVD burn to my Macbook Pro running Viata with ImgBurn. Burned a few copies, works on couple TL so far.
#43
A-spec steering wheel ftw
hey a bit off topic but related to teh nav discs...i'm in an 04 TL, and i want to buy a new nav disc, but i can't seem to find where they show the changes per disc.
i.e. basically the most important thing i want to know is in the state of Missouri, does the 3.70 version reroute since highway 64/40 is down atm. (i know you can check somewhere on this, but for some odd reason i can't find it >< )
#44
Originally Posted by pg_rider
So ImgBurn works pretty well for this? I just bought an LG dual-layer burner at Best Buy and a stack of Memorex DVD+R dual layer discs. Hoping it works the first time.... Do you have to change any settings in ImgBurn to enable the dual layer burning? Does it matter where it puts the break for the dual layer?
Nothong to change to enable DL. Be sure you flash to the latest firmware. I used the hacked firmware which can be found at www.rpc1.org.
Good luck
#45
Imgburn works fine with my Vista. Just burn the disc via 2x or 2.4x and leave your computer alone. Don't surf or play games. You don't want to waste your $1 DL-DVD on a bad burn.
#46
Not sure I follow what you're saying -- what do I need to flash to new firmware? The TL's nav system?
#47
Flash your DVD burner. The Hacked version of most DVD single layer can turn into a DL, plus region free forever, overclock, and more. The single layer DVD burner may not work with Double layer without the latest update.
#48
4.62 Navi Burned - but in loop
Burn went perfect. Got the standard error message the first time I put in the new version. It downloaded the updates and Navi works. I turn off the egine after its all complete and start over and it goes into Self Diagnostics detection. I can get out of it by hitting "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu. I can then go into Navi Test and then hit exit diagnostics and it brings up the Safty screen. Unfortunatly I can't seem to get out of this loop.
Any thoughts?
Any thoughts?
#50
Make Nice, Not Rice
Originally Posted by joeybabyluvsu
How does the Navi traffic work for those who have it? I cant figure it out yet....
Through an XM subscription WITH an additional $3 monthly charge for its live traffic update.
#51
B16 Swapped TL
Originally Posted by LoveMyTL-S
Not sure if the TL's Navi will read dual layer DVD's.
I completed the upgrade myself. DL DVDr+
#54
Originally Posted by Igor911
You can use Nero to burn the ISO as well. Pretty easy if you asked me...
If you set your ISO file associations in windows to open with Nero, it should only take you <5 clicks to burn.
#55
Keep in mind that you are getting this update free, please be nice and patient since it may not work the first time. Burning DL-DVD is a pain in the butt.
Good luck all.
Good luck all.
#56
Originally Posted by Mojo7
Hey NDe, I foudn the ImgBurn freeware and please show me what the 3 clisks are to burn the DVD. Thx.
#57
this seems pretty easy, just download it and burn it iso on nero. Im gonna try this tomorrow on my 06 tl. Has anyone had success with this besides igor????
#58
07 TL-S
i did this on my 07s, burned a dl dvd and just stuck it in the trunk dvd player and everything worked as advertised. some new streets were added by my house, and all the gas stations have the icon of the brand. this is in the toronto area.
#59
There shouldnt be a problem but ive noticed that anybody with an 04-06 (3.XX) never reports success/failure with their efforts
#60
It should be okay if you find the right version to download.
#61
I need some help, what the heck am I doing wrong. Check this out. I have 2007 Navi TL
I burnt (on a brand new Quad core Dell) using Nero Ultra 7.5 at 2.4x. I insert it into DVD and prompts for 4 dig password. I do it. It works and I got out of the car. later I got back in car and I will describe it like this: Navigation takes 2-5 seconds to boot up, but then goes to Navi Diagnostics.. Only way out of It is doing CAN/MAP/MENU and then it returns to the 'Press Ok' which i do and it works.
I figured what the heck, so then I burned same image on Same Memorex DL at 2.4x with a Maddog triplestor burner but same result. Need to CAN/MAP/MENU to start it.
Is there something im doing wrong or could it be a bad image? It works perfectly once I do this, but each time I get back in car....
#63
I am using the recommended imgburn software performed the copy and all went well. I put the disc in the car, held the three buttons then clicked version. From there I clicked download. It said it was downloading the data then the words go away leaving only the gray screen. I have to turn the car off to leave this screen.
What am I doing wrong?
07 tl burning 4.62
07 tl burning 4.62
#64
07 tl burning 4.62
07 tl burning 4.62
#66
07 TL-S
07 tl burning 4.62
07 tl burning 4.62
#67
Downloaded it online and burned it to a DL DVD
Igor911, Please give me some help. Ive burned 2 copies now using same DVD's but different burners and different computers (both Nero 7.5's). When I inserted the first DVD it said it needed to update FW which it did. Then it asked for my navi code which I entered the 4 dig code. Then it worked. No issues. Next time I got in car it and ever since, it takes about 4 seconds longer to get off the Navi splash screen keeps going into Diagnostic mode and after the tones I can Can/menu/Map and it goes back to next screen where I can press Exit then it goes to the standard navi 'OK' and it works.
I've burned both at 2.4x and disks work so it's not that. Is nero screwing up something?? any ideaS?
#69
Nav 4.62 backup successful
Here is what I did:
I used dvd Decrypter and made an ISO image. With that image there was also a .MDS file. The MDS file is a CD image file, and MDS is the corresponding catalog file which I believe uses the ISO and puts them in a certain sequence/order. Open DVD Decrypter, go to Mode--->Click on ISO---->click on the write option. Then go to source and open the file with .MDS extenstion. Make sure you have both the ISO file and .MDS file in the same folder. Change you write speed to 2.4x. I tried doing this with several different DVD+R DL. The brand that worked for me was Pengo. I hope this helps you guys make backup copies. I have made 1 for each of my vehicles and they work perfectly.
#70
Acura Newbie
#73
Originally Posted by Xerlude
Guys,
thanks for all the info, I'm burning the disc now, hope it works on my 04
#74
Originally Posted by blipszyc
Flipper - next time you're at the Can/Menu/Map screen, go to the 'version' page and hit load. That should re-load the appropriate files and reset the nav. Hopefully that will eliminate the Diagnostic screen stuff.
Thanks.
#75
Crap, now I loose my male voices and didnt accomplish anything!
Anything else to try?
#76
4.62 goes to diagnostics at car start
blipszyc and flipper - I also have the same issue on car start goes into diagnostics. Have reloaded the updates and still each time I start the car the diagnostics comes back up. Tomorrow I am going to put the original back in and try to do it all over again and see what happends. Will post following.
#77
Originally Posted by scott2
Here is what I did:
Bravo!
x2 works like a charm! Did two cars
#79
Here is what I did:
#80
Did not work. It did the download but as soon as it was done it went back to diagnostics. I'm about to give up. Is there a problem with my image/iso?
You may want to try a different brand of DL-DVD. Also try using Imgburner and burn the DVD at 2.4 speed.
