just did the imposible (fixed my cd changer)
i was so upset that my cd changer went dead, would not load any disc. load and eject would not function at all, only was able to use radio, tape and xm. i was ready to buy a second radio but i knew that either way i had to remove the old one out. So before buying it, i took a chance and took everything apart. i remove the radio and opened it, found that all my cd were jam and since i could not remove them i just had to break them all After removing all the broken cd parts i notice that the motor for the cd changer was still jam so i help the motor reach the end. All of the sudden my cd changer started working 100% like before. I'm glad i didn't spend the xtra money on a second set.
i have to get an isimple or any other ipod mp3 player cause i really didn't care much about the cd changer until now.
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0180-1.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0178.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0177-1.jpg)
![](http://i177.photobucket.com/albums/w207/eduardmc/IMAG0181.jpg)
That's good to hear. I guess at that point you have nothing to lose. Is there anything you can clean or lube to help it out?
Let me tell you, this cd changer must have like a thousand moving parts inside, i never thought it would work but if anything is broken inside, u will not be able to replace it. My first inspression after removing the cds inside was " wtf did i get into". I Believe that if for any reason it goes bad again this is one mod ill not try again.
SidhuSaaB
05-30-2020 12:40 AM
