JL cleansweep vs any LOC
I have a jl cleansweep installed and the hissing sound is very annoying. I'm thinking about swapping it out with a loc.
Are there any differences in sound between the JL CS and a LOC?
I'm sure a few TL members in the past have switch from JL CS to Loc, How do you guys feel about it?
I used to own a
I'm about to go to the store today and buy a LOC to hook up my amp and sub out of my old car. I'd like to know if you think something more advanced is needed. I plan on upgrading my other speakers and amps later so I've been thinking about something like a 3Sixty...
Not thread jacking - just have the same question...
Because I don't like the EQ of the factory HU, I ran into an EQS first, then to the JL, but the voltage seemed high enough to run direct without any LOCs whatsoever. Much cleaner too!
Have you tried just going direct to the amp? depending on the sensitivity of the amps inputs, it might be able to take it straight from the low level ins of your factory amp. The least amount of devices between your head unit and the amp delivering power to your speakers, the better your sound quality is going to be.
Originally Posted by playboyace35
Hm, I haven't tried it yet, but I think your setup only works like that because you have a jl amp. I don't recall why that is tho...
You could always just get a JL amp, instead of spending on the LOC.
so is loc better than cleansweep?
In the Acura's case it will take the high level signal AFTER the stock amp and make it a usable signal low level for you new amps
The cleansweep and other signal processors such as the 3sixty will equalize the signal to it to adjust for head unit and cabin acoustic problems. They can take the signal input as either a low level signal or high level. Think of these signal processors as fancy equalizers. Some such as the rockford 3ixty.2 have time alignment functions.
Is one better than another? They are similar devices, hard to compare one to the other. LOCs are generally less expensive that signal processors.
Hope that helps explain things
I skipped on the whole 360 thing from rockford n cleansweep from JL and went with locs.....they seemed to work better with the original system and let the clean sounds the stock radio produces get through without "attempted filtration" from some other device.... I also have a 3 input 3 output crossover from clarion that clarifies the music even further, its sick. the hissing sound is most likely coming from the jl unit. Gain is too high somewhere.
Depending on how the lines are pulsed and what they return is how I would go about converting a stock system to something with some extra kick.
Originally Posted by King of Pain
A LOC will take a high level signal (such as a speaker signal) and reduce it to a low level signal (such as a pre-amp signal) that can be used by amps. That's all it does.
Hope that helps explain things![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
What I didn't realize was that perhaps my situation was unique because I happened to choose JL Audio amps.
But in general, isn't it better to minimize the devices in the signal path? Thus, eliminating the factory amp and use of an LOC theoretically should be a cleaner signal (and less to fail) over just amping the low level output from the HU. That's all I was suggesting...
Weird - I didn't choose that amp for that reason either, I must have just gotten lucky. You might be right however, there's LOTS of smarter people on this forum than I and everyone talks about LOC's, so there must be scenarios where they're required.
You could always just get a JL amp, instead of spending on the LOC.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
That's why I am choosing to stick with my cheap amp. (hifonics brutus 1606d)
Thanks for the input though.
(Can anyone verify exactly why JL amps do not require loc and such, or am I just tripping?)
I wrote down the settings the installer used so I could change it back.
King - what I was saying wasn't what LOCs were necessarily, I know what they are. All I was saying is that bypassing the factory amp completely is also possible in our cars by taking the low level inputs of the factory amp, and run them back and go to the inputs of an amp.
If your are eliminating the factory amp you do not use an LOC. You use a line driver such as the audiocontrol matrix. A line driver will boast a very weak signal.
http://mobileaudiocontrol.com/produc...49&l1=5249&l2=
A Line output converter will reduce the signal from the stock amp. Such as the LC6 from audiocontrol or the NE-774V from Navone engineering
http://www.mobileaudiocontrol.com/pr...2&l1=17612&l2=
http://www.davidnavone.com/cart.asp?24&cat=7
Two very different devises that do two very different functions.
My current set-up is:
Stock Head unit going to the Stock Amp. Navone LOCs used after the stock amp going to Alpine PDX Amps. No hiss, no distortion, nothing, nada, zero. Very clean highs and punchy low end without sounding weak. I don't even get hiss from the CarPC Sound that is connected to this set-up.
All my ground wires go to a block and the main ground wire (4 gauge) from the block is attached to the bolt on the back of the trunk next to the fuel pump, left side I beleive. I seems to do the trick.
you NEVER ground anything near any pumps.... make new holes... make your own ground. the system is always going to be safer that way and greatly minimizes the risk of shorting the cars electrical if anything ever happens.
alan_rich
09-07-2015 11:08 PM
