JL Audio Cleansweep Confusion
I have a question about the JL Audio Cleansweep. Do I need a Cleansweep SSI and a Cleansweep DSP at the same time? I know I definitely need a Cleansweep DSP, but Im not sure if I would need a SSI as well. (I have a high amplified interior speaker system where I am have noticeablle distortion mainy in the front speakers at high volumes.)
Also I'm confused about the master volume control on the Cleansweep DSP. I have been hearing 2 different things about the master volume control. I'm sure that someone can clear this up for me...
1) That I can still use the Radio/Steering Wheel/Stock Volume Control to control the volume without messing up the equalization/flatline effect that the CLeansweepgives me. Basically I wont have to use the cleansweep's master volume control and the cleansweep master volume control is needed for only for an aux. line.
OR
2) I must use the Cleansweep Master Volume control to control the entire car's volume to retain the cleansweeps automatic flatline/equalization. (Basically I should keep my radio at a constant volume and just use the JL Audio Master Volume Control knob)
Thanks in Advance!
OR
Thanks in Advance!
Mobile Elec. Guru
i just did a system for a another board memeber in his 05 TL at our shop using just the Clean Sweep DSP. It worked fine and ended up sounding great. As far as the volume control goes, if you get it installed correctly and tuned well you could get away with just using your main radio Volume Control, although this does slightly effect the effectiveness of the cleansweep. It is suggested both in my opinion and by JL to use the clean sweep volume knob as the primary volume control so that the cleansweep can most effectively work.
2005 WDP TL
Mobile Elec. Guru
Originally Posted by kyle-wdp
Did you or have you ever had a problem with acceleration noise with the cleansweep? Mine has some, I checked my grounds and don't know what else to do....any suggestions?
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
