iSimple questions
iSimple questions
I just purchased the required i simple accessories (PXAMG & PGHHD2c) for my 2007 TL Type S, and, after finally getting it to work, the controls are extremely slow. Is this normal?
What do you mean by "slow". Do you mean, when you are going between "SAT", "iPOD", etc.? If that is what you are talking about then occasionally mine does that too. Or if you mean that it takes a while to change songs and stuff like that, then I occasionaly have that problem when it is pretty cold out. I hope this helps
Mistuh DRiiVA
i would check your connections to see if everything is plugged in properly. when i had my temporary setup in the car the ipod cable would become loose from the isimple unit causing it to react very slow because the connection wasnt secure. i would check to make sure its all the way into the unit.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
